Maximum Boost??? - Diesel Forum - TheDieselStop.com
Old 10-26-2009, 09:41 PM   #1 (permalink)
Matt0987's Avatar
Maximum Boost???
I am trying to find what the maximum boost is on my 03 ex 7.3L auto.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Matt0987 is offline
Old 10-26-2009, 09:54 PM   #2 (permalink)
klhansen's Avatar
My Photos: (169)
Load it up with everything you can find, head out to the steepest hill you can find, and put the hammer down. When the gauge peaks, that'll be the maximum boost for your truck.
Stock boost is between 15-17 psi, but you have a tuner on it, so you should see more than that.
Hard or no-start? Check Here
klhansen is offline
Old 10-27-2009, 12:18 AM   #3 (permalink)
Matt0987's Avatar
I don't have the gauge yet. That is why I am looking for the max. So I don't buy a gauge that is too small or too large.
Matt0987 is offline
Old 10-27-2009, 08:33 AM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (44)
The turbo boost red line is 25 PSI.
Max safe boost with a stock turbocharger is 25 PSI. So you want a gauge with the max at 30 PSI. If the gauge scale goes over 30 PSI, then that makes the gauge harder to read at a glance in the critical area around 20 to 25 PSI.
As for as attainable boost, then 15 to 17 PSI pure stock, about 21 with excellent intake and exhaust mods and stock tune, and the sky's the limit with a hot-rod tune. But your limiter is the turbo itself, and if you make it produce more than 25 PSI using a go-fast tune, it won't last long.
SmokeyWren is online now
Old 10-27-2009, 12:07 PM   #5 (permalink)
Matt0987's Avatar
Matt0987 is offline
