Mechanic says he's never seen anything like this - Page 2 - Diesel Forum - TheDieselStop.com
Old 10-18-2012, 05:49 AM   #16 (permalink)
tinman13kup's Avatar
Kevin is saying that if the hubs are NOT locked in and you put the t-case to 4-lo, power is sent to the front axle but stops there. Without the hubs locked to connect the wheels to the axles you get a 2w-lo.
It sounds like you would have the exact same operation with the warns that you have now. You twist to lock the hubs, and when you don't want them anymore, you disengage them.
The biggest downside to leaving them locked is the binding when going around corners and reduced fuel mileage. If you consider not having to mess around with the hubs and having them work a downside, then you can count that too
Tom
99.5 PS CC 4x4 SRW ZF-6
- AKA "The Big White Truck"
tinman13kup is offline   Reply With Quote
Old 10-18-2012, 05:56 AM   #17 (permalink)
FWIW, I replaced the ESOF hubs with Warn manual hubs on my 2001. Fine with me to switch them in when I need them. As KLHansen said, leave em locked if you think you might need 4WD. Dodge trucks are always locked, as they do not have hub disconnects. Sure a bit more wear and slight fuel economy hit, but the manuals always work, whereas the ESOF system does have a number of failure points that tend to go bad at the worse time.....
I got mine from Napa for like 100 bucks... not the premium, but good enough.
Coolhand
2001 F250 SC LWB 4WD 7.3L Auto - 143K - 17 to 19 MPG
2006 F350 CC LB 4WD 6.0L Lariat G/N Hitch 4285mi - 1 Turbo Trashed 1600mi, MetaL in Oil, Bad instrument cluster - significant oil leak - Sold at a Loss!
1979 Ford F250 4WD 460 4 Spd BW T18 Dana 60's Motor Not Stock 7 MPG....
Too Many other Ford Trucks to List but My First was a 1958 F100 2WD 3spd 240 cid Six....
Coolhand is offline   Reply With Quote
Old 10-18-2012, 11:55 AM   #18 (permalink)
I found a place in town that has the Warn Premiums in stock for $282, so I'll be putting them on later today. Hopefully that will stop the vibration. Even if it doesn't, at least I'll know that I'll have a good set of locking hubs that I can depend on. I'll post here on whether or not that took care of the vibration problem. Thanks for the input.
Scott
Early 99, 4WD
Skydiver is offline   Reply With Quote
Old 10-18-2012, 12:38 PM   #19 (permalink)
I too, for what its worth, keep my hubs locked almost all year long as I am continually going from pavement to off road conditions multiple times a day. To get out and lock and unlock the hubs each and every time I needed 4x4 would be crazy. Only when I know I'm going to be out on the highway for several hours or going on a long paved highway trip do I unlock the hubs. Been doing this for over 6 years with the factory hubs and so far so good. Did the same thing in my old Toyota Landcruiser for about 5 years and never had a problem.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, CCV Canister Style Mod, AIS w/sleeve, Fuel filler mod, GOS headlight harness, Hella 80/100s, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny, 26 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Donaldson ELF7405 oil filter, billet thermostat housing.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DTRS and BPP kill switches, DIY "pitstop" switch.
http://community.webshots.com/user/l...host=community
losfinch is offline   Reply With Quote
Old 10-18-2012, 11:13 PM   #20 (permalink)
Well, I now have nice new shiny Warns on my truck but still have the vibration issue. Crawled underneath the truck today and found that at the carrier bearing I could push the drive shaft up about 1/4 to 1/2 inch. Don't know if that's possibly the problem, but at this point I'm just going to have to take the truck in to the mechanic and bite the bullet.
Scott
Early 99, 4WD
Old 10-19-2012, 01:06 AM   #21 (permalink)
klhansen's Avatar
My Photos: (175)
I'm pretty sure that my driveshaft carrier bearing moves about that much inside the rubber mount, and I don't have vibrations like you're describing.
Not sure what could be causing it. I do know that vibrations and noise can telegraph all over to sound like it's coming from somewhere other than the actual source.
Hope you figure it out.
Hard or no-start? Check Here
Old 10-19-2012, 01:14 AM   #22 (permalink)
For what it's worth, many years ago I was driving a Chev 5 ton and had similar symptoms. Decelerating the truck would shake violently, step on the throttle and it would smooth out. Turned out to be the right side motor mount was toast. Maybe worth a check.
Evel486 is offline   Reply With Quote
Old 12-09-2012, 11:52 PM   #23 (permalink)
westvandude's Avatar
I just put new esof hubs on mine. $389 delivered from Tasca parts on ebay.
Didn't solve my bearing noise and they still don't work in AUTO mode, but looking at my vacuum hoses from the axle in the wheel well I'm gonna replace those and then do more diagnostics from there.
Here's a useful video:
Personally, I think there's nothing wrong with the esof system. But like anything on a 10+yr old vehicle rubber hoses need replacement, etc.
I had manual hubs on my Toyota pickup and to be honest, I hated getting out in the mud/snow to twist the hub locks.... your wife/GF won't appreciate it either. So why give up the convenience for a few bucks less? You'll soon eat up the fuel in the mpg difference of driving around locked all the time. Then the manual hubs will show no savings in the long run.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, NAPC 450series trans w/billet triple disc TC, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 2000w inverter, Tekonsha Primus, 220A HD alternator, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. REVO tuned. AS7609 navi head unit 7" touch, Custom fiberglass box MD Sound 12" & Boss NXD5500 amp. Tint is next.
westvandude is offline   Reply With Quote
Old 12-10-2012, 10:13 AM   #24 (permalink)
Also check your trac bar bushings. Brother's '00 had similiar problems and finally found wheel unit bearing and bad trac bar bushings. Good luck!
2001 F250 7.3 4x4 4r100 Shortbox Crew
Ford AIS filter
31 Row 6.0 cooler
Dieselsite Trans filter
Autometer EGT/Trans/H2O Temp guages
Driven Diesel bowl delete Reg Ret(soon)
DP Tuner (future)
4" MBRP Exhaust (future)
Seatbelt minder mod
CCV mod
delreyr is offline   Reply With Quote
Old 12-11-2012, 01:28 AM   #25 (permalink)
So.... $2.78 for 6' of vacuum hose and now my brand new replacement esof hubs work like new. :-)
If you don't have binding auto hubs (dial really hard to turn) chances are first culprit is the vacuum lines in the wheel well running from the upper fender liner down to the axle spigots. Less than 2' of hose either side takes 5mins or less to replace both sides. Just turn the wheel full left then right to do each side easy as pie.
Plastic spigot on top side and metal spigot on axle. Just pull either end off, remove old hose. Route new hose thru hose retainers, plug in top and bottom.
I have two wheel hub bearings for the front axle so gonna swap them in over the next couple weeks. I might get started this weekend.
If that doesn't cure it then it's either trans, driveshaft or rear axle.
Old 12-11-2012, 09:37 AM   #26 (permalink)
Since nobody has mentioned the slip join on the drive shaft I'll throw that into the conversation since that is something that seems to go unchecked but is the least expensive and easiest to check for vibration issues. Don't forget to chock the wheels!
2002 F-250 7.3 4x4 C1 Axle
cghoerichs is offline   Reply With Quote
Old 12-11-2012, 11:35 AM   #27 (permalink)
sailpadre's Avatar
my automatic transmission torque converter was doing the same thing-vibrate at slow speeds and go away under normal conditions. It wasn't unlocking.
2002 F350 Lariat LE dully 4X4, black, BD engine brake, 4" turbo back exhaust/magnaflow muffler, GTP 38R, AFE cold air inlet, coolant filter, Edge juice/attitude/1500 Evo, ARP studs, lock out torque converter and shift kit, 2 vane performance radiator, 410 gears
2005 38' HR Next Level, 18,000lbs loaded,
2 slides, 5.5 kv Onan, 40 gal fuel station
Trailer Mate air cell hitch
sailpadre is offline   Reply With Quote
