More danger possible to turbos at higher elevations? - Diesel Forum - TheDieselStop.com
Old 10-27-2009, 02:17 PM   #1 (permalink)
At higher elevations, where the air is thinner and hence less resistance for the turbo to work against, is it possible to overspeed a turbo before actually seeing dangerously high boost numbers?
For example, would the boost numbers for a given turbo RPM be the same at sea level as they are at 8,000 feet above sea level?
What I'm thinking is that at higher elevations one would need to be much more conservative with the boost numbers that they allow since you could over-speed the turbo (to the point of damage) before actually seeing dangerous levels of boost. And, if this is true, how does one know what the safe boost levels are for different elevations?
Anybody know more about this?
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, custom bed carpet/bench inserts, Rhino grill guard, Bugshield, mud flaps, CCV Mod, AIS w/foam sleeve, Fuel filler mod, GOS headlight harness, Hella 80/100s, 02-04 Headlights, Rancho HD steering stabilizer, C-Btr Mirrors, Hella FF1000, Sonnax/Tricumulator, Htr Bypass valve, 31 row 6.0 tranny cooler,front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DTRS and BPP kill switches, DIY "pitstop" switch.
http://community.webshots.com/user/l...host=community
losfinch is offline
Old 10-27-2009, 04:08 PM   #2 (permalink)
klhansen's Avatar
My Photos: (169)
Just making a partially educated guess here, but I don't think it's the RPM that's the limiting factor on the turbo, but the pressure across it and the thrust that it develops along the shaft. I believe the thrust bearings are usually what goes bad.
So the altitude effect would be fairly small.
Sea level 14.7 psia intake to 15 psig boost is 29.7 psi pressure difference.
5000 ft ~ 12.2 psia intake to 15 psig boost is 27.2 psi pressure difference, or about 8% LESS.
Maybe a turbo rebuilder will weigh in.
Hard or no-start? Check Here
klhansen is offline
