hello all
i have a 2000 f350 sd cc 4x4 wth 95k miles on it
i have recentally noticed a little shimmy or vibration at highway speeds.
then every once in a while a cyclic lunking like a caliper is loose. but it goes away sparatically
i took off the tires and hte calipers and pads are fine. i noted on the passenger side that the "needle" bearing location there is some sort of washer or dust cover i guess that is loose and can be wiggled by hand with everything intact. the drivers side is tight.
i have read the forums and guzzles and roosters pic shows very nice indeed.!
however i feel it is a littl outside my comfort with the reseating of bearings and the factory ford yellow o ring etc.
i went ot my local ford dealer today and for the low cost of 38$ and 4 hours of my time they lifted it adn test drove it. no rumble, clunk or vibration on test drive, no recommendation of needle bearing replacemnt he says its hte hubs are not fully unlocking.!!
my esof is working fine as far as i can tell. the ball joints were done at 60k or so.
they want $480 a piece plus an hour install to put on new hubs and they keep talking about thespecial tool.
so................................
my questions are
if the washer / dust cover on the needle bearing is loose should it be replaced. if i replace one should i do both?
#2 are my hubs toast? if so replace them my self adn which brand should i get, new ford oem , warn or other?
#3 is there a special tool needed to replace the hubs or just the needle bearing?
#4 apart from teh torrington bearing reference is htere aftermarket parts to use or should i just get oem?
thanks in advance and of course in the past for the cps, vss, od switch, fuel line o ring and oil change help! not to mention air intake tire size and mods!
thanks again
live long, drive father!
B
