hello new to this great site...I have owed 2002 diesel excursion limited since new. Love this truck, retired last year and hadit painted put in chip k/n air intake 4"exhaust leveling kit looked ran great......... On the way home from hunting noticed sudden drop in mpg from 18 to 12 ish!!!!! truck ran well same power everything ....... checked for leaks reset back to stock(mpg fell accordingly..2to3mpg more).... reinstalled mileage program (after updating)same mpg........ I'm lost HELP!!!!!!!!!!!!
Boost is your biggest culprit behind mileage loss. One would think you would have noticed the power change. It could also be that the truck isn't getting proper feedback - from boost (MAP sensor) or one of the other monitored parameters. A blocked EBP tube / clogged sensor has been reported to cause lower than normal MPG. A faulty ICP sensor or EOT sensor could also affect mileage.
Are you checking MPG manually or with a scanner? Do you have access to AutoEnginuity or some other scanner to monitor PIDs?
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
thanks for reply RT...the mileage was done manually;however the hunting trip is 15 hrs. oneway,through country about the same as kentuky or tennesse on I 75 quite hilly!!! Have religeously used injector cleaner,oil changes ect... pids????
Basically, monitoring individual sensors through the PCM feed. You could set up a scanner (such as ScanGauge II) to monitor ICP sensor data or MAP sensor data or EOT sensor data using appropriate PID's - here's a link to the one's for ScanGauge - Ford Specific XGauges : Linear Logic : Home of the ScanGauge
AutoEnginuity is a great tool to have when doing diagnostics. It will let you monitor multiple parameters over time to see what's going on (or at least what is being reported) as you drive.
yes have had up on hoist multiple times looking for fuel leak!! (asphalt driveway would show quickly) How much are these monitors??? Don't want to take 10 yr old truck to dealer!!!!!
AutoEnginuity with the Ford Enhancement is $359. You run that off your laptop. It is the ultimate diagnostic tool. ScanGauge II is about $160. You can monitor four things at once, but can't initiate any tests. I use it predominantly for economy feedback - I keep one on instant MPG and one on trip MPG. The other two I usually watch ICP sensor data and voltage. I change them around depending on my mood. AE would be the better choice for diagnostics.
Check your front hubs are not locked in. I loose about 2-3 mpg with front end locked. I also loose 2-3 mpg with winter blend fuel. May want to check all calipers and make sure you don't have one frozen up and dragging. Unless you have fixed your fuel tank, you may not be getting a full tank each time. Some have cut the vent tube off inside the tank which allows you to fill up quicker without the foam issues. I can get 5 more gallons in my tank without standing there to 5 more minutes to get a full tank.
__________________ LED running lights below doors for turn signals, marker lights, and courtesy lights from JadSolution
FOKISD (Ford, Ohio, Kentucky, Indiana, Super Duty Club), Charter Member.
2001 F-350, PSD, 4X4, True Blue, 152 WB, SRW, Auto Trans, Manual Hubs, PMT3, Off Road Package, AIC, Heated Excursion Tow Mirrors w/cut off switch, Extang Tonneau Cover, Westin Step Bars, Lund Bug Shield, Nifty floor mats, Custom rear bumper/w fog reverse lights & 3rd brake light, LED running lights below doors, Poron USA reverse backup sensors.
"It's mine,ALLLLL mine, (Till Andrea wants to drive it)"
Thanks PSD trucks going in monday to change fuel filter and make sure hubs are free and front axels are disengaging!!!! Had the right side not disengaging about five years ago ... wore out the tire... going to keep fingers crossed!!!!
