is my lift causeing my cruise control to be inop - Diesel Forum - TheDieselStop.com
Old 11-06-2009, 03:26 PM   #1 (permalink)
hey all been reading some threads on the cruise control and just cant seem to get it. I have a 2002 f-350 7.3 lifted 8" on 38 i was wondering if maybe the lift may have something to do with it. I just had the recal done still nothing i really didnt feel like payin them to scan it an give me the run around to charge me an arm an a leg. im not sure if its the vss or what but the systum i have is pretty much no power push the on button to the cruise then hit set and nothin happens no light on the dash nothing. anything would help thanks
willbsh is offline
Old 11-06-2009, 04:38 PM   #2 (permalink)
woodnthings8's Avatar
Try this test procedure out, don't have your foot on the brake pedal during this test.
Enter the Self-Test Diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel will flash once to indicate that speed control module entered the diagnostic mode. Five additional flashes at this point indicate a defective speed control servo. Release the OFF switch.
Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
If the "ON" switch is not depressed within five seconds after entering the diagnostic mode, the module times out and the procedure must be started over.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
NOTE: There will be a slight delay when the last button is pressed and the lamp flashes.
A lamp flash with the last button (SET/ACCEL) indicates that the STATIC test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
Flashes Source
2 Flashes BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped) is defective
3 Flashes Deactivator switch is open or circuit defective
4 Flashes Vehicle speed signal is out of range or circuit is defective
Immediately after the STATIC test, the speed control servo does a DYNAMIC test by automatically actuating the throttle lever from 8 mm (0.315 in) to 12 mm (0.472 in) of travel from the idle position. During the DYNAMIC throttle pull, observe throttle movement to witness any binding or sticking of the speed control cable and correct connection of speed control cable to throttle lever. Make sure the throttle returns back to the idle position.
Return the ignition switch to the OFF position and proceed to the Symptom Chart.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 11-07-2009, 09:00 AM   #3 (permalink)
fill out your signature and let us know about your truck.... year, options, tranny...stuff like that. You'll get more responses.
Oh, and welcome to The DieselStop!
'00 F350 XLT, DRW, CC, 7.3 PSD, 6 speed, combo 90 gallon fuel tank/tool box, Banks Stinger-Plus, 203º T-stat, A-Pillar ISSPRO guages, Hadley Air horn, PowerSlide rear window, AIC, AIS, KCM S.S. HPX Line, Riffraff FRx.
Member # 10965
HorseHauler is offline
