I am getting ready to rebuild my turbo and everything running to and from it. I already have 4in turbo back exhaust just need to install it. What all do I need? Everything is stock.
You need the rebuild kit. Get an install kit from diesel orings. Order a few extra hex bolts as they tend to be missing. New boots. Possible wastegate upgrade. Plenum inserts.
Well - this would be the perfect time to do up pipes since you'll have the turbo off anyway. It is a two man job, so round up some sucker to lay under the truck and catch all the debris while you bolt everything in.
How's your pedestal? Any leaks?
I'm doing similar to you right now. I'm doing new 4" exhaust, BD up pipes(wrapping them w thanks to dieselnick), turbo rebuild w SP Turboost center section, new pedestal w ebpv delete & RiffRaff CAC boots. I've got a more comprehensive list on my laptop I can add Monday. Try to stay away from that thing on the weekends.
Parts used:
• Shelor Motormile 2U2Z9K635AA 1999-2003 FORD F-SERIES SEVERE DUTY AIS
o Easy install, fits great
• MBRP EXHAUST STORE MBRP-S6200BLK MBRP 4" Turbo Back, Single Side Black Coated
o Good Quality, Slight fitment issue. Didn’t care for the fact that one extension tube had to be cut to size to fit a standard bed crew cab.
• SP Turboost CO. 811-1206-002 GTP38 TURBO UPGRADE CHRA SPX BILLET WHEEL
o Great looking quality. Shipped promptly.
• Riff Raff GZ-14-010 GTP38 Compressor Housing O-ring
• Riff Raff GZ-14-060 Garrett Compressor Housing Outlet O-ring 99.5-03
• Riff Raff GZ-9-003 Turbo / Pedestal O-rings
• Riff Raff 451274-0005 Garrett GTP38 High Flow Outlet
• Riff Raff 702670-0002 Garrett Non-EBPV/ Blank Pedestal 99.5-03
• Riff Raff 6032168312 Turbo Pedestal Bolt Kit 99.5-03
• Riff Raff GZ-14-012 Garrett 12pt Replacement Turbo Housing Bolts
• Riff Raff RDPHHPX Stainless Steel HPX 99-03
• Riff Raff RDPABK9903 Complete CAC Intercooler Boot Kit 99-03
• Riff Raff RDPPRI RDP Plenum Reinforcing Inserts
• Riff Raff B005-7.3 Intercooler Boot Complete Clamp Kit
o All the RiffRaff items were of the best quality. Obviously I’ve purchased a good amount from them and will continue to give Clay my business in the future.
• Xtremediesel.com BD1043900 XDP 7.3L Bellowed Up Pipe Kit
o Good build quality. All the welds look top notch.
• O'Rielly Auto 22433 Gates Upper Radiator hose
o No more removing the radiator hose to change the serpentine belt!!
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
