Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-19-2009, 01:45 PM   #1 (permalink)
Location: Moberly Missouri (about 30 miles north of columbia)
Need Help Asap
Have a 99 7.3 that is giving intermentant problems with wts light not comming on and check engine light not coming on and no start and then today was driving truck and it died and wouldent refire till after it was towed home and sat for about 3 hours it is throwing a code of P0603 pcm processor keep alive memory (kam) error dont know if that is the problem or not any help would be appriciated this truck is stock with 4in exhaust as the only mod and has 146xxx miles on it
2000 Ford F-250SD balanced 7.3 6speed with Hypermax h2e turbo 530 injectors afe stage 2 air intake, fluid damper, twin 5 in turn out stacks, south bend duel disk clutch, ts 6 position chip, 18k mod, head studs,Built by BWD thanks Brian
2005 Ford f-250SD 6.0 auto with a steroid modual
lpfd778 is offline
Old 11-19-2009, 03:05 PM   #2 (permalink)
When you turn it over when it wouldn't
start was the tach moving it could be the cps
redrocker is offline
Old 11-19-2009, 08:09 PM   #3 (permalink)
i didnt look at the tach but would that cause the wait to start light and the check engine light not to come on at all
lpfd778 is offline
Old 11-19-2009, 08:28 PM   #4 (permalink)
F350_6's Avatar
My Photos: (5)
Check fuse # 30 to make sure it's not blown. Also check the main engine wiring harness (big harness with red striped tape over the drivers valve cover) to make sure you don't have any wires shorting against the valve cover below the 42 pin connector or wires behind the connector shorting against the metal bracket.
In the future, if the WTS ligth does not come on, don't waste the battery juice trying to start the truck. Just turn the key back off and see if the WTS light comes on next time. If the WTS light does not come on, the truck will probably not start.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 320,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
