Need help, just lost a bolt!!! - Diesel Forum - TheDieselStop.com
Old 03-07-2005, 04:02 PM   #1 (permalink)
I was installing my new exhaust and took the nut off of the clamp that holds the down pipe to the turbo, and lost the bolt some where. Now I can't find it, and I really don't know where it ended up. Just called Ford and they said, it will cost $25.00, and will get it in a day. Man I am pissed........you guys have any helpful hints on how to tackle this once I get the new clamp? Thanks alot.
'01 F-250 Crew-Cab,powerstroke....4 inch exhaust,air intake,SCMT,Extang tonneau cover,Isspro guages. Family hauler/daily driver.
Bill
Dzlcrw is offline
Old 03-07-2005, 04:24 PM   #2 (permalink)
Re: Need help, just lost a bolt!!!
It is probably sitting in the valley at the back of the engine or it rolled and is sitting on top of the transmission. Get a flash light and start looking. One of those magnets on a telescoping pole like you find at Autozone might help.
Also see if you can feel around the top of the transmission with your hand.
Tbar
99.5 F250, White, CC, PS, Auto, 4X4, 3.73, NVK3, 4"exhaust, twildman 4-position chip, 3-piller mt w/Ispro gauges, VDO oil pressure gauge, SW water temp gauge, Amsoil Lubs, Coolant Filter, Racor445, Zoodad, TC Lock Up, Bilstien Shocks, Cab Lights Hooked to Turn Signals, Side Marker Lights hooked to Turn Signals, Hutch Fuel Line Repair #1 & #2, Harponed Fuel Tank, Tymar HPX, Garmin GPS-V, Glasstite Topper, Rugged Gear Gun Mt, Procomp Steering Stabilizer, Fumoto Drain Valve, JNB Fuel Mod, AFE Air Filter, Kenwood TM-D700 dual band radio
TBAR is offline
Old 03-07-2005, 04:34 PM   #3 (permalink)
I have tried all of that, and still can't seem to find it!! I guess I'll have to order a new one.
Bill
Dzlcrw is offline
Old 03-07-2005, 04:44 PM   #4 (permalink)
Ok, you have an air compressor? Try blowing it out............. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Tbar
TBAR is offline
Old 03-07-2005, 04:57 PM   #5 (permalink)
Unfortunately, I have no compressor, but actually found the bolt, so tomorrow I'll make sure and have some help!!
Bill
Dzlcrw is offline
Old 03-07-2005, 05:00 PM   #6 (permalink)
Where did you find it???
Tbar
TBAR is offline
Old 03-07-2005, 09:39 PM   #7 (permalink)
On top of the tranny!! Hopefully I can find the nut now. It's always something. If not I'll have to run to Advanced Auto to see if they have anything. Already tried Home Depot, and they did not have anything.
Bill
Dzlcrw is offline
Old 03-07-2005, 09:54 PM   #8 (permalink)
When I lost the same nut I tried the big stores (ie...Hoe Depot and Lowes) with no luck. If you have a small Local Hardware store (Handyman, Ace Hardware, etc...)try them. I shop at the big stores all the time but I normally have to go the small stores to find the odd sized nuts and bolts. We have three different small shops within about 15 miles of me (owned by different people) and all three of them cary the odd sized stuff. Don't know why the big stores don't stock 'em......but normally they don't.
Glad to hear that you found the bolt.
Good luck with it.
99 7.3L PS E-350XLSD with Ambulatory roof.
(((XM))) Satellite Radio
4" turbo back Diamond Eye exhaust (portadiesel)
Pair of K&N High flow filters
HPX Hose from D.I. (blew out.....pulled it and plugged now)
In-tank and prepump mods (homemade version)
203* thermostat (dieselsite)
Tru-Cool 4739 MAX Transmission cooler (dieselsite)
Boost Relief Valve (dieselsite)
Pillar mount Di-Pricol gauge set
Sonax/tricumulator (Black Cloud)
Jody flashed econo tune PCM (DP-Tuner)
Van specific regulated fuel return (ITP)
70k miles driven annually...mostly pulling 8 1/2 foot tall 7x14 enclosed trailer
Cruise on at 61mph and 1736rpm's I don't stop 'till she needs more go juice!
stroked_van is offline
Old 03-07-2005, 11:13 PM   #9 (permalink)
drdenny1's Avatar
Thats where I found both of mine, on the tranny.
Good luck,
Denis [img]/ubbthreads/images/graemlins/cool.gif[/img]
2000 F350 SD 4X4 CC LB Lariat
4"DPPI Turbo back
aFe Magnum
50/80/110 Bill's flip chip W/PMT1,and a DP 120
A-Pillar Autolites Trans/EGT/Boost-GOS Racing
APCM(AIC)
Boost Bleed off
4" Lift W/315's
Dual alt's.
ATS housing
Wicked Wheel
Banks 1.0 A/R housing
ISSPRO TTM
Warn Premium Hubs
J/S IDM
Racor 4500 CCV
ARG SuperPump and Gear
GOS Racing-Head Light Harness
2004 Sprinter 292FWRLS
SOLD: 97 F250HD CC SB 4X4 7.3L E4OD 4.10
drdenny1 is offline
