newbe needs help - Diesel Forum - TheDieselStop.com
Old 02-24-2013, 10:37 PM   #1 (permalink)
Question newbe needs help
02 7.3 bought new runs great,but only when cruise control is set,when not using cruise control there is a miss only between 50 and 65 mph.Higer or lower speed is good.I use the word miss but rpm or speed stays the same,but you feel the hesitation==hit the cruise control and everthing is perfect ==Thank you for any info==I have had this truck over 10 years 120,000 miles and no big time problems==need help==
ed-lo is offline   Reply With Quote
Old 02-25-2013, 02:50 PM   #2 (permalink)
May be a throttle position sensor. They are fairly inexpensive and easy to change out.
2000 PSD Excursion Limited owned since new, Mickey Thompson Classic II Wheels, V Code Springs Front, Modified B Code Springs Rear, Rear Hellwig Sway Bar, 3 Autometer Gauges On The Pillar, DP Tuner 40hp tow, 80hp tow, 80hp Econo, 140hp Extreme, High Idle Tune, Custom 4" exhaust and muffler, Custom Tranny with TCS 3 Disc Converter, K&N FIPK Intake, Garrett GTP38R Ball Bearing Turbo.
ColoradoEX is offline   Reply With Quote
Old 02-25-2013, 04:46 PM   #3 (permalink)
newbe needs help
Thank you for your response,as i had no idea where to start.After viewing this site over the last few days i am certain that i have found a home,specially since my truck is getting older and will start having issues beyond my limitations. Again Thank You--
