Check you glow plug relay. The light on the dash is controlled by the pcm. The relay could be bad and you would have no way of knowing. To check it get a meter or a cicuit tester. There are two 5/16" posts o. The gpr. One should have a cover and one is uncovered. The one not covered is usually closest to the middle of the engine, but not always. The covered one should have 12v all the time and the uncovered one will have 12v for up to 2 minutes. Now if the engine oil temp is warm the pcm will still give the wts light, but the relay will not come on, so make sure the truck is somewhat cold. If you get 12v on both sides you may have worn out glow plugs, which at the mileage you listed is not suprising if they are bad. Changing them is no big deal, pull the valve covers and swap them out. They can get a build up on them that makes them hard to remove, so be careful pulling the old ones.
Ken
Powerstroke Acronyms
TSB Information
