No power - 2000 7.3 - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 06-02-2007, 09:03 AM Thread Starter
No power - 2000 7.3
This AM I started and drove about 3 miles and suddenly the check engine lite came on and the engine power dropped to the point that the truck could hardly move itself. I limped it home and parked it.
Looked under the hood for loose or unplugged wiring but found none.
Where do I start looking to cure this problem? Thanks, Dave
thunderc is offline
post #2 of 9 (permalink) Old 06-02-2007, 09:18 AM
Re: No power - 2000 7.3
Scan for codes. Check oil.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
post #3 of 9 (permalink) Old 06-02-2007, 09:32 AM
What Arisley said.Did it sound like it was running on a few dead cyls.?if so Check UVC harness's
2000 F350 CC Lariat 4x4 Auto,Dp-tuner F5 stock,80e,120r,140a,Terminator Hpop,DDP B-codes,Fluid Dampr,BTS Trans,zoodad mod,TN turbo.
14.2 @ 94mph 1/4 mile
Boggerr is offline
post #4 of 9 (permalink) Old 06-02-2007, 09:36 AM Thread Starter
Thanks, What are the UVC Harnesses? Dave
thunderc is offline
post #5 of 9 (permalink) Old 06-02-2007, 09:46 AM
Under the Valve Covers, there is a connection on the valve cover gasket, in the valley in the center. Sometimes they come disconnected at the outside connection.
Andy
arisley is offline
post #6 of 9 (permalink) Old 06-02-2007, 09:48 AM
NCHornet's Avatar
If you have a SES or CEL it means you have a stored code. Get the codes read and you will know where to look. The UVC would be a good guess but it could also be several things. If you live near me I can scan them for you.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #7 of 9 (permalink) Old 06-02-2007, 09:56 AM
Top inside center of the vavle covers,you will see a connector that runs into the valve cover.Make sure they are in all the way,jiggle them around alittle and start the truck see if it clears up.That connector is part of the vavle cover gasket FYI.
Boggerr is offline
post #8 of 9 (permalink) Old 06-02-2007, 11:18 AM Thread Starter
Checked the code. Fuel injection - I checked the plugs and both were tight and all the way in. I unplugged the passenger side and it run the same. Unplugged the drivers side and it would not start. Passenger side must be bad - heading to get one at Ford. I'll let you know if thats the fix. Thanks, Dave
Pulled the passenger valve cover and found that the plug to the injectors & glow plugs had come loose. Replaced the valve cover gasket anyway while I had it appart. The truck has 140,000 miles on it and have been told that the connection between the plugs in the head gasket burn out. The plug seems to fit tighter. Hope it does not come loose again. PROBLEM FIXED!!!! Thanks for all the help!!!
thunderc is offline
post #9 of 9 (permalink) Old 06-02-2007, 01:12 PM
Did you look at the UNDER valve cover wiring ?...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
