No power under load/tow - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 08-11-2009, 01:47 AM Thread Starter
I have a 2000 F350 with 7.3 diesel. It drives normal around town and on highway...but put a small trailer behind it and it is struggling to go 70mph and pulling moderate hills at 45mph in 2nd gear. (2000lb trailer). I replaced fuel filter, air filter, cleaned a little soot out of the EBP tube. I took it to a shop and no codes come up and boost and turbo are OK. This truck use to pull a big enclosed trailer at any speed and no problem. Any input would be appreciated! (All stock engine, no chip/exhaust/intake)
stealth motorsports is offline
post #2 of 5 (permalink) Old 08-11-2009, 08:38 AM
woodnthings8's Avatar
You say boost is ok, what kind of numbers are you seeing? I can't imagine a 2000# trailer is causing that much of a difference. I would think it is probably not pulling to capacity even when unloaded. It is probably just more noticeable when towing. Are you seeing higher or lower RPM's? If your trans is slipping it will limit you towing and may not be as noticeable unloaded. Also the shop you took it to, what kind of scanner did they use? A shop should have a full capability scanner but some of the generic ones will not read codes on our trucks.
Some things to look for are;
1) Soot on the up-pipes to the turbo, if they are leaking you are not getting full exaust pressure to build boost.
2) Look at the EBPV to make sure it is fully open, creates a restriction in the exhaust.
3) Check your intercooler tube boots to make sure none of them have blown off or are split.
4) Check the Wastegate actuator to make sure it is hooked up correctly.
5) Check fuel pressure (requires a gauge and a adapter)
6) Make sure the oil is not excessively over due for a change
7) You may also need to run some diagnostics on the High Pressure Oil System to make sure you are getting full oil pressure. (will require hook-up to a scanner by a dealer or shop with a quality scanner)
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #3 of 5 (permalink) Old 08-13-2009, 12:33 AM Thread Starter
I went to the shop today and they found I had 15lbs of boost, turbo tight and good, no leaks on the intercooler or turbo hoses. The y did a cylinder contribution test and said #8injector may be clogged or bad. They flushed the injectors and put some stuff in my fuel. I read that the grey CPS may throw a code falsely blaming #8. I don't know my fuel pressure at the bowl. What do you think? What do I do now? (no change in power)
Any info or suggestions welcome....I need to fix this truck!
post #4 of 5 (permalink) Old 08-13-2009, 09:44 AM
You can get a fuel pressure tester at most auto parts stores for around $50 you will need an adapter like this Ford 7.3L Powerstroke Fuel Pressure Gauge Adapter Fitting You can probably get an adapter like this locally too, just look around. I think if your truck is running fine unloaded going up hills you are getting enough fuel though. Does your trailer have brakes? There is a chance that the brakes on the trailer could be dragging and causing the extra load.....just a thought!
15-17 psi on a stock truck is about right, maybe a little low but not a huge amount. You could try disconnecting the line to your wastegate actuator and plug it, See if that helps you any. Some guys disconnect it all the time to get the actuator closed longer. You could have a bad wastegate solenoid allowing pressure to the wastegate actuator all the time.
Ken
post #5 of 5 (permalink) Old 08-13-2009, 12:12 PM
I would drop the tank and check the screens in the mixing chamber or do a pre pump filter mod.
2002 F-250 CC 7.3 TS Performance 6 position chip(High Idle, Stock, 50, 75, 100, 140) Open air element, Walker BTM, Full Gages, boost fooler, 3.73 gears, 125,000 miles and counting.
holeshotkid is offline
