Normal oil pressure?? - Diesel Forum - TheDieselStop.com
Old 06-28-2005, 12:19 PM   #1 (permalink)
My Photos: (21)
Who knows what is normal oil pressure for a 7.3L? I installed an oil pressure gauge yesterday and I get...
22 psi @ hot idle
55 psi @ hot 2000 RPM
85 psi @ cold idle
Thanks,
-john
1999 F-350 6-Speed SRW CC LB 3.73
jas10 is offline
Old 06-28-2005, 05:00 PM   #2 (permalink)
klhansen's Avatar
My Photos: (169)
Re: Normal oil pressure??
You have GOOD oil pressure [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Service CD says 10 psi at curb idle and 40-70 psi at 3300 rpm.
Hard or no-start? Check Here
klhansen is offline
Old 06-28-2005, 06:24 PM   #3 (permalink)
Texascadillac42's Avatar
My Photos: (10)
Yep, that O.P. sounds great. I get 55 at cold start, 30 at hot idle, and 55 at operating temp @ 2200rpm.
99 F350 XLT 4x4, Crew Cab, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
Texascadillac42 is offline
Old 06-28-2005, 06:42 PM   #4 (permalink)
I'm getting ready to put in an oil pressure gage. Where sre you guys putting your sensor?
2008 F-350 King Ranch CC LWB 4x4
Neal_P is offline
Old 06-28-2005, 07:40 PM   #5 (permalink)
My Photos: (21)
I put mine in the manifold on the oil filter housing. There's a 1/8 NPT plug there. Just remove it and install your sender.
-john
jas10 is offline
