O-Ring kit for Front Hubs - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 10-31-2006, 12:29 PM Thread Starter
Ok, I know I've seen the part number for this front hub kit here before but can't find it now when I need it!
Hubs are in good shape, just need to replace the o-rings.
Can someone point me in the right direction?
On edit: Forgot to mention, they are the factory manual hubs, not the vacuum ones
2002 F-350 DRW 4x4 ESOF PSD
Lariat, CC, LB, White, 4R100, 4.10LS, TT, Tony Wildman 6-position Chip, Open Element Intake, Walker BTM, Wicked Wheel, X-Monitor Gauges, Sonnax-Tricum, AIH Delete, Tinted Windows.
Y2KF250PSD is offline
post #2 of 15 (permalink) Old 10-31-2006, 08:08 PM
Ran440's Avatar
Re: O-Ring kit for Front Hubs
O-ring (hub/bearing assy, inside) Big yellow one
F81Z-4A322-AA $2.23
Locking Hub O-ring
F81Z-4A322-AA
$4.40 through International and about $7.00 through Ford
www.powerstrokeshop.com is a good place to shop for parts for our trucks.
Randy
1999 ( Build date 10/98 ) 1-Owner F-250 XLT PSD, XLE8 ( started out as XLE4 ), Auto Trans w/sonnax valve tricumulator springs, 4x4, manual hubs, manual shift transfer, 3.73 gears, Tymar intake, open air CCV, A-pillar 3 gauge W/Auto Meter pyro, boost, trans and axle temp in Mag-Hytec covers, Banks 4" monster exhaust, DI 4 Position Flip Chip stock-75-100-110, early 99 turbo conversion W/ ATS BB Turbo, gutted EBPV, Smitybuilt bumper guard, Lund bug deflector, Lund SS cold air grill guard, Wet Okole seat covers w/Powerstroke logo, custom made floor mats ( way better than any store bought mats )
Buy American, Keep Your Job.
Ran440 is offline
post #3 of 15 (permalink) Old 10-31-2006, 10:29 PM
klhansen's Avatar
My Photos: (180)
Last time (well, really the only time) I got locking hub o-rings, they were only available as a package of two (one for testing, and one for final installation) with the clip ring that holds the hubs in.
I'll have to remember to post the part #, (don't have it on this computer). IIRC, the package was around $11 [img]/ubbthreads/images/graemlins/vomit.gif[/img]
), AIS,
regulated return,
klhansen is offline
post #4 of 15 (permalink) Old 10-31-2006, 11:11 PM
robf250's Avatar
Might be a dump question [img]/ubbthreads/images/graemlins/shrug.gif[/img] why replacing the o-rings in the hubs?
I got the same year truck. I have no power in my front axle right now, I haven't had a chance to see why I have no 4 wheel drive. Also, can't turn the hubs to lock it in. Is that why replacing the o-rings. If so, seems to be a easy fix.
2000 F-250 XLT, Ext Cab, 4x4, Auto, 3.73, Triple A-pillar w/Phantom AutoMeter Gauges, ZooDad W/6637 mod, Dp Tuner-80 hp Economy, Airlift Airbags, Home made bug guard, 4" MBRP turbo back exhaust, Tru-cool and Shell Leer 100LE.
1991 YJ Jeep
robf250 is offline
post #5 of 15 (permalink) Old 11-01-2006, 10:16 AM Thread Starter
Thanks Guys,
Ran440, you listed the same part number for both o-rings....... typo or do they both come in the kit?
RobF250, The reason for replacement is because when the hubs got a bit hard to turn, I removed the hubs and lubed them with transmission fluid. While it did loosen em up, I evidently didn't drain them well enough and the tranny fluid must have ate up the o-rings because now they are mush.
post #6 of 15 (permalink) Old 11-01-2006, 01:35 PM
klhansen's Avatar
My Photos: (180)
Randy (Ran440) got the part #'s from me a while back, so I'll take the hit for the duplicate numbers. I discovered the error a couple of months ago, but didn't broadcast it to everyone I'd sent my list to. I didn't remember to get the right number at home last night. Sorry.
The hub o-rings I got were the ones that seal between the hub/bearing assembly and the locking hub itself. They seal the vacuum at that interface for the auto hubs.
If it's the o-ring around the knob you're looking for, I don't have a number for that. Your best bet would be to take the disassembled hub to a plumbing shop and find one that fits.
), AIS,
regulated return,
klhansen is offline
post #7 of 15 (permalink) Old 11-01-2006, 05:03 PM Thread Starter
Ok...... so the part number that Randy listed is for the o-ring that goes on the outside of the locking hub.
Now I just need to come up with the one that seals around the dial on the inside and I'm guessing thats the "big yellow one" that I hear discussed so frequently.
Thanks Folks!
post #8 of 15 (permalink) Old 11-01-2006, 07:22 PM
klhansen's Avatar
My Photos: (180)
No, that part # is for the big yellow o-ring that goes behind the wheel hub/bearing assembly (where it bolts to the knuckle).
I'll put a yellow sticky note on my forehead to remind me to post the right part# for the locking hub-to-wheel hub o-ring.
), AIS,
regulated return,
klhansen is offline
post #9 of 15 (permalink) Old 11-01-2006, 08:52 PM
Ran440's Avatar
Sorry. I'll edit my parts list.
Randy
Ran440 is offline
post #10 of 15 (permalink) Old 11-02-2006, 12:24 AM
klhansen's Avatar
My Photos: (180)
OK, the sticky note worked. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] Here's the right # for the locking hub mounting o-ring.
Locking Hub O-ring (2) & retaining ring
4C3Z-1K106-AA
), AIS,
regulated return,
klhansen is offline
post #11 of 15 (permalink) Old 11-02-2006, 01:18 PM Thread Starter
Thanks for the part number KL!
I'll see if I can locate a source for the o-ring that seals the selector dial.
post #12 of 15 (permalink) Old 11-02-2006, 01:22 PM
A while back, member rocinbaja posted some great instructions on rebuilding the stock auto hubs. I'd like to add some info on sourcing the o-rings. After 325,000 mi, mine were puking the o-rings out and I don't want to pay the dealer $275ea for new hubs.
The exterior 0-ring is AS568A-152
Fractional size 3 1/4 x 3 7/16
Actual size 3.237 x 3.443
Width 3/32 (0.103)
The interior o-ring is AS568A-142 (the 143 size is ok also)
Fractional size 2 1/8 x 2 9/16
Actual size 2.362 x 2.568
Width 3/32 (0.103)
I ordered some of these in a buna-n material from McMaster-Carr (www.mcmaster.com) for about $10 per pack of 50. For the Buna-n material, the McMaster nunbers are:
9452K173
9452K148
Bearings are INA #SCE248
I have extra orings, so if you need a few, drop me your address and I'll mail them.
'02 F350 CC LB XLT 4WD SRW 335,000mi no mods
'03 F350 CC LB Lariat SRW 90,000mi
State College, PA
Kirk Whitaker is offline
post #13 of 15 (permalink) Old 11-02-2006, 01:27 PM Thread Starter
JKWhitaker,
You are da man!!!
I'll send you a PM!
post #14 of 15 (permalink) Old 11-02-2006, 03:52 PM
Keep in mind this is for the factory auto (vacuum) hubs. Don't know if they are different from the manual hubs.
State College, PA
post #15 of 15 (permalink) Old 11-02-2006, 04:03 PM Thread Starter
Thanks for the heads up......... as far as I know the only difference is the vacuum diaphram so the o-rings should work.
I hope
