Oil capacity - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 04-24-2007, 03:42 PM Thread Starter
Airframer509's Avatar
Oil capacity
Hello all,
I am at the point of my first oil change on my newly acquired 2002 F350 Powerstroke Diesel. What is the capacity with filter change for this engine? How many quarts should I buy?
Thanks for the info.
02 F350 XLT Powerstroke crewcab longbed 4X4
Airframer509 is offline
post #2 of 8 (permalink) Old 04-24-2007, 03:47 PM
Re: Oil capacity
I buy 4 GALLONS and use most of it. Any left over I keep in a tool box in the bed of the truck.
2k F250 XLT CC 6sp PSD, 3.73 LS axle, Superchip, W-D Turbo Brake, Memphis speakers & 5ch amp, WD-Pyro & Boost gauges, Rechargable MagLite, quick disconnect jumper cables, CAT batteries, ARE tonneau,
"una
able" on the tailgate!! New door actuators!!
T-304 Stainless exhaust turbo back, Southbend clutch
Tina is offline
post #3 of 8 (permalink) Old 04-24-2007, 03:48 PM
Re: Oil capacity
Sit down as you read this. The 7.3 with no mods (you can get a larger oil pan) holds 15 quarts. Yup, 1 shy of four gallons. Be sure to fill up your new filter before putting it on the truck and it holds about two quarts.
Good luck and welcome to the site.
Hello all,
2000 Ford F250 PS 4x4 long bed.
build date - 7/31/99
Truck mod(s) - performance
4" MBRP, TS 6 Pos.Chip (valet,hi rev, 50, 75, 100, OMG), BTS Valve Body, AFE Stage 2 Pro Guard 7, ISSPRO Guages, 203 thermostat, AIH Delete, Wicked Wheel, Edge EZ, ball joints with grease fittings, Detroit lockers front and rear.
Thanks to DPPI, Diesel Site and Heavy's Customs
interior/exterior dressing -
JVC stereo and speakers, Ranch Hand brush guard, TSC over the rail tool box, HiJacker 5th Wheel Hitch, Tekonsha Voyager, Down Underseat-Holding Apparatus
WARNING - Poweraid 400-595 is junk (my experience)
Soon - BTS Transmission and Torque Convertor, mud flaps
drainman is offline
post #4 of 8 (permalink) Old 04-24-2007, 03:54 PM
Re: Oil capacity
15qts.
Wells
mtnbkr132 is offline
post #5 of 8 (permalink) Old 04-24-2007, 04:37 PM
Diezel Dawg's Avatar
Re: Oil capacity
16 quarts with oil filter and u will be good to go
Ken
99.5 7.3L PSD 4x4
WOP GQSSB TURBO
Tyrant Diesel Tunes
TYMAR Intake
Casserly 250cc Hybrid Injectors
BTS
496 hp 985 tq!! 16 Apr 11
13.74 sec in 1/4 mile @ 98.5mph
PNWFDE#2
Diezel Dawg is offline
post #6 of 8 (permalink) Old 04-24-2007, 07:46 PM
SmokeyWren's Avatar
My Photos: (45)
Re: Oil capacity
And you'll be one quart overfull.
I buy 4 gallons, and be sure the engine is warm before I begin.
First step is to pour one quart into a clean empty quart oil container, then seal up that one quart and put it back until around the 4,000-mile point, when mine usually needs that one more quart.
Second step is to turn the new oil filter in the box so the hole is looking up. Then fill the filter full of new oil - almost two quarts. Keeping the new filter in the box until just before you're ready to screw it on helps prevent uh-ohs!
Next, loosen the oil filter to be certain it will come off.
Next I use a long skinny flat-tip screwdriver and a claw hammer and punch a small hole in the bottom of the old oil filter. Take a break while the filter drains. Then remove the old filter and screw on the new filter.
Be sure your drain pan will hold almost 4 gallons of used oil. A 5-gallon bucket works for me.
Then pull the drain plug (or rotate your Fumoto drain valve) and let it drain. Collect a mid-stream oil sample of about two ounces to send to Blackstone Oil Analysis. Take a long break and let it drain really, really good.
Then install the drain plug (or close the Fumoto valve), and fill it up with what remains in the 4 gallon jugs of new oil.
Clean up your mess, properly recycle the old oil, and celebrate.
I did mine Sunday morning. That's about the 30th oil change on Sierra Blanca, and she's still runnin' strong. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
An if you don't already have a Fumoto oil-drain valve, get one before your next oil change. http://www.fumotovalve.com/
SmokeyWren is offline
post #7 of 8 (permalink) Old 04-25-2007, 09:33 AM
2003f350's Avatar
Re: Oil capacity
I just changed mine 2 days ago [only 10th. time for me]. It always takes 15 qts. to fill it.
Ed
2003 F-350 Lariat Supercab 158" WB, 3.73 LS axle
7.3 PSD, auto trans. camper pkg. 12,500 lb. hitch,
adj. pedals. roof lights, Toreador Red, Arizona Beige, Power telescoping mirrors, and C-Betr mirrors. Delivery date Aug. 5, 2002. Reese 16K hitch, Thor Citation- model 29 5P 5th. wheel, Rhino liner.
2003f350 is offline
post #8 of 8 (permalink) Old 04-25-2007, 01:12 PM
Re: Oil capacity
I cheat and use 14 quarts, so I have the left over half gallon for the next oil change.
2000 F-350 4X4 Diesel Welding Rig
70' Lincoln SA200 powered by a Red Seal Continental
"Weld It And You Wont Be Screwed"
bigblue250 is offline
