Oil gone bye bye - Diesel Forum - TheDieselStop.com
Old 12-24-2007, 11:06 PM   #1 (permalink)
jwehrer's Avatar
Oil gone bye bye
Drove the truck tonight about 5 miles round trip and after I drove into the garage, I walked around behind my truck to go into the house and see this trail of oil from the street up the driveway behind my truck. Uh Oh. I'm thinking HPOP? However, wouldn't this be more than just O-Rings? Or when they go, does it discharge oil that fast? Dipstick only shows about 1/2 inch & it was full this morning when I checked, so it lost most of the oil just now. Any ideas would be appreciated.
2001 F350 4x4 XLT Lariat Crew Cab, 7.3 Liter PSD 6-speed Manual, Warn Hubs, Manual 4WD, Long Box, Century Canopy,
jwehrer is offline
Old 12-24-2007, 11:12 PM   #2 (permalink)
Re: Oil gone bye bye
sounds like a HPOP line popped off or sprung a leak. I'd check that first..
2000 F350 CC SB SRW 4x2 7.3L
Work in progress...
DP Tuner 4 position chip Stock, 80e, 100p, 140e, 4" magnaflow turbo back, afe stage 2, 4R100 with shift kit/heavy duty clutches
and more to come...
Items waiting to be installed: BDP Stage III Hybrids, Beans Modded H2E
Future mods: BTS trans, fuel system, studs, PULSE HPOP
matthewd11 is offline
Old 12-24-2007, 11:17 PM   #3 (permalink)
jwehrer's Avatar
Anybody have an illustration of the HPOP with where the lines are?
jwehrer is offline
Old 12-24-2007, 11:51 PM   #4 (permalink)
Diezel Dawg's Avatar
Id have to agree that it is the HPOP lines or a leaking oring at the pump. I had a friend who had a major leak like that and it was his HPOP orings i believe
Ken
99.5 7.3L PSD 4x4
WOP GQSSB TURBO
Tyrant Diesel Tunes
TYMAR Intake
Casserly 250cc Hybrid Injectors
BTS
496 hp 985 tq!! 16 Apr 11
13.74 sec in 1/4 mile @ 98.5mph
PNWFDE#2
Diezel Dawg is offline
Old 12-25-2007, 12:00 AM   #5 (permalink)
Just had what sounds like the same rate of leak on mine. Ended up being the hpop resevior gasket. Kind of a pita to fix. I think mine was one of the rare ones and agree that your first look should be at the hpop orings. Good luck, it took me about 5 tries to determine where it was leaking as mine would fill the valley so fast, I couldnt see any dripping. If you cant see the leak right away you will probably have to clean the valley with degreaser and inspect with a mirror and flashlight. Be patient.
2002 f-250, cc, long bed, 4x4, 4 inch lift, 295/75-16 BFG all terrains, dp-tuner stock, 40 tow, 80 econo, 6.0 transcooler, 6.0 intercooler, aih delete, wicked wheel, autometer gauges, tymar intake, 4inch exhaust, mag-hytec diff cover, power slot rotors/hawk lts pads, built trans. 125k on the clock and counting..
ragenford1 is offline
Old 12-25-2007, 01:10 AM   #6 (permalink)
JimTJr's Avatar
My Photos: (20)
Check the valley of the motor, (I am sure it will be full) You may be leaking bad enough to see it without cleaning it. But if you can't see it while running. Then clean it thoroughly with rags, and use brake parts cleaner. Once it is completely clean, have someone start the truck, looking for the leak. (You may need a mirror and flashlight)
there are a few places it could be leaking from. But yours sounds pretty major... mine leaked much less from one of the lines right here, these are next to the fuel bowl, drivers side.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 12-25-2007, 07:15 AM   #7 (permalink)
jwehrer's Avatar
Oh yeah, the valley's full of oil and it's all over the top area of the engine and other apparatus aft of the fuel bowl, so it's gotta be more than just a drip if you know what I mean. When it gets light this morning, I'll have the wife start it while I'm up over the engine and I'm sure I'll see the culprit. Assuming there's enough oil left in the engine to start. Thanks for the advice.
jwehrer is offline
Old 12-25-2007, 09:33 AM   #8 (permalink)
JimTJr's Avatar
My Photos: (20)
If it is still on the stick, your probably fine for a quick start. (I think the sticks has marks only indicate 2qts.
If it is NOT on the stick I would top it off, why ask for more trouble, (hard start, wearing the oil pump, ect...)
JimTJr is offline
Old 12-25-2007, 01:25 PM   #9 (permalink)
jwehrer's Avatar
Good point. 3-4 gallons of Delo 400 is pretty cheap relatively speaking. Incidentally, how much oil do you end up losing doing the O-Ring R&R? just what's in the reservoir?
jwehrer is offline
Old 12-25-2007, 06:28 PM   #10 (permalink)
jwehrer's Avatar
Ok, Had my wife start it and it's definately leaking out of the end plug on the aft end of the HPOP. I mean it's just streaming out of it. Now maybe I'm being optimistic here, but that appears to be a very easy fix (Outside of the major cleanup job I have ahead of me). ratchet it off (it appears to be very easy to get to). New O-Ring and torque it back on. Is it really that simple?
jwehrer is offline
Old 12-27-2007, 07:37 PM   #11 (permalink)
jwehrer's Avatar
Ok, now that it's all fixed and cleaned, I have another question for the experts out there. What's the best way to clean my garage floor & driveway? I still have the wicked oil trail all the way up the driveway and into the garage.
Jim
jwehrer is offline
Old 12-27-2007, 07:49 PM   #12 (permalink)
I use a commercial grade concrete cleaner...Got it at Napa....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline
