oil leak , how much to fix - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 05-31-2006, 04:35 PM Thread Starter
hi all , i am no mechanic so i hope someone can tell me how much this is going to cost me . i've got an oil leak at the front of the engine by the hpop i believe it's called ( the square looking box by the fuel filter) and also by the turbo ( the thing at the back ) . it's got oil directly under these spots in the valley . i've read that the most likely causes are the turbo pedestal and hpop o-rings ? now how much am i going to pay the dealer to fix this ? i'd rather pass out now than in front of a group of people , lol! thanks . [img]/ubbthreads/images/graemlins/confused.gif[/img]
gazoo is offline
post #2 of 7 (permalink) Old 06-01-2006, 01:59 AM
Re: oil leak , how much to fix
I realize you said that you are no mechanic, but this job isn't hard at all. If it is one of the HPO lines and it is leaking at the HPOP, there is an o-ring kit you can buy from the dealer for $25. Its an easy job to do, even without the oil line removal tool. You will need a stubby wrench (I made my own with a hacksaw! lol) to get in there without removing the oil lines. I've never had to fix a turbo pedestal leak (yet), but I know others have done it many times.
Roger
2002 F350 XLT, CC, SB, 4x4, Auto, AIC, DiabloSport Predator, BD X-Monitor, Kenwood TM-V7A, Pioneer 7400MP3, Infinity 5.25" Components, Infinity 10" Sub in a Q-Logic Box, Heated Mirrors, Gentex/Mito Auto Dimming Mirror, Rear ID Bar, Uniden PC78 Elite CB, Clifford Matrix RS3 Alarm/Remote Start, Keypad Entry, Homemade "Tymar", custom, muffler back exhaust, 6 Whelen LED's in rear window, 6 Whelen Strobes in the Front, Rears still not installed...
96Cobra is offline
post #3 of 7 (permalink) Old 06-01-2006, 02:04 AM
klhansen's Avatar
My Photos: (180)
If you don't feel like tackling it yourself, it may cost you an arm and a leg at the dealer. Or, it may cost you $100.
Depending on how many miles and how old your truck is, it may be covered under Warranty. The engine (including oil leaks) is covered for 100,000 miles or 5 yrs from the date first sold. The deductible for the warranty is $100.
If you're outside the warranty, then [img]/ubbthreads/images/graemlins/frown.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
), AIS,
regulated return,
klhansen is offline
post #4 of 7 (permalink) Old 06-01-2006, 12:34 PM
Cost me a little over 300 bucks, at a non-dealer mechanic, if that gives you an idea.
White '02 F250 CC,LB,4x4, Full replacement front and back bumpers, 33x12.5R16 SSR 52Rs on 16x8 Rims (no lift or leveling), aftermarket sound.
DoubleMeat is offline
post #5 of 7 (permalink) Old 06-01-2006, 12:56 PM
it cost me $180.00 at a ford dealership. I will do it myself next time....
glust is offline
post #6 of 7 (permalink) Old 06-01-2006, 03:27 PM
Is there a cheaper place to get the o-ring kit? I hate spending that much on a couple o-rings. The stealership hit for $12 for 2 rings seals when i did the water pump. They ended up coming with the new thermostat and housing so I took them back right away.
Late '99, F-250 7.3L, PSD, Super Duty, AT, 4X4, Crew Cab, 235 Mich tires, MBRP 4" Exhaust, 4-setting DP-Tuner (set for +80hp Econ mode), K&N Filter and Intake Tube, 203 thermostat, coolant filter, A-Pillar Isspro gauge set (pyro pre-turbo, trans temp, boost), Turbo Master Wastegate Controller, 6.0L tranny cooler, BTS valve body, rebuilt trans at 196K mi, bilstein shocks, Chevron Delo 400 10-40w, Zoodad mod, late model cup holder.
No time left for Drinking.
jdkluge is offline
post #7 of 7 (permalink) Old 06-01-2006, 04:01 PM
I have had the two o rings under the fittings that go into the head for the HPOP oil lines leak on me 3 times. I have had them repaired at shops because of time available, I am going to do these myself.
I am also thinking the special hose end fittings need to go and be replaced with JIC fittings. Then they will not leak.
99.5 F250SD 6 speed Ext Cab Long Bed/Custom Grille/ Hood/ DPPI 4"down w/dual tips/AFE II/ Evans Coolant w filter& 203 Deg. thermostat/ARE bed Cap/Centerline Tracker 9 x 16 w Michelin 265/70/16 /Brite Box/ Gear Vendor OD/Line X bed Liner/ATS Turbo Housing/Velvet ride Shackles/X Monitor EGT & Boost/ TS 4 position chip/Air Dog/ DI Fuel Tank sump/DI High Perf. fuel delivery system/DI External fuel regulator bypass kit/ Centramatic wheel balancers/05 Headlights
MrBee is offline
