Oil Leak from intercooler hose - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 02-27-2009, 09:47 PM Thread Starter
texaspsdx's Avatar
I have oil leaking from the intercooler hose where it connects to the intercooler on the passenger side. What is my problem and how do I correct? Thanks.
Ron
2000 F250 CC LWB, PSD/Auto, AIC, Edge Insight CTS, 4.10 w/Detroit TrueTrac, 6.0L 31 row Trans Cooler
SOLD - 2000 Excursion Limited 2x4, PSD/Auto, ATS turbo shroud, 4" exhaust, HX crossover, ISSPRO gauges/A-Pillar, Pre-Pump & In-Tank Mod, Banks TransCommand, ZooDad, Baldwin Oil ByPass, AIC, F350 rear springs, Helwig Rear Sway Bar
1983 Avion 34V - 35' travel trailer,
Hensley Arrow No Sway Hitch
texaspsdx is offline
post #2 of 8 (permalink) Old 02-27-2009, 10:56 PM
tattoocharlie's Avatar
My Photos: (5)
oil is intorduced to the intercooler system via your ccv(crankcase vent)so oil is not circulated through(like a oil cooler line would)the intercooler system.but because the ccv system feeds into this oil accumulates in variuos places.if you have a leak i would suspest you either have a loose boot or a boot with a hole in it.you should be able to purchase new boots and install them to correct the problem.but verify it is coming from the boot.not a cracked line or the intercooler itself.
2002 f250 lariat 7.3 220k(motor has 190k)
original 4r100 tranny....220k and counting
knock on wood....
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
post #3 of 8 (permalink) Old 02-28-2009, 04:41 PM
jgarden's Avatar
I disagree that new boots are the answer. If you have excess oil in the system (as I had) it will get through - even new boots. I installed a CCV catch can and that solved most of the problem - at least until the residual oil leaked out of the IC hoses.
TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Jack
jgarden is offline
post #4 of 8 (permalink) Old 03-01-2009, 01:14 AM
My Photos: (5)
i didnt say new boots will fix it i was explaining that oil builds up in the intercooler system,but being oil is petroleum it will soften rubber boots and potentialy lead to failure.
knock on wood....
4" exhaust no muff
post #5 of 8 (permalink) Old 03-01-2009, 02:01 AM
Bill1013's Avatar
If you need new boots go here Diesel Power Products | OH150 | 99-03 Ford Powerstroke 7.3L Hose Kit
If the boots are not soft or spongy from the oil, wash them with soap and water use Dawn dish water soap. Dry them off good. Spray the metal tube ends and the turbo ends with hair spray and slip the boots back on, DO NOT over tighten the clamps, tighten just so they do not squeeze into the boot, the hair spray will sort of glue them.
The oil in the intercooler tubes is natural, lots of mods have been tried .
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #6 of 8 (permalink) Old 03-01-2009, 10:07 AM
jgarden's Avatar
Actually, what you said was, "you should be able to purchase new boots and install them to correct the problem." To me that sounded like new boots are the answer, sorry if I misinterpreted. In my limited experience (just with my own truck - and almost 10 yrs of watching and reading on this site), new boots certainly was NOT the answer.
You can see an old post of mine Oil in valley - from intake boots? after CCV mod.
I never followed up with the conclusion to this issue, but it was indeed residual oil in the intercooler (at least I presume), b/c it eventually stopped leaking from the boots.
These are the boots I used on my truck - 1999.5-2003 7.3L DIESELSITE Engine Boot Kit (After 12/1/98)
So anyhow, if you have oil coming from the boots, my advice to do the CCV mod. That said, it seems some trucks simply have MORE oil going through those boots than others. For many people simply removing the boots, cleaning them inside and out really well and reinstalling is good enough for another 50k. For me cleaning them worked for a few thousand miles. For me installing new aftermarket "oil proof" boots was good for a little longer. I guess my truck has enough blow by that the CCV mod was only answer.
I suspect had I done the CCV mod first, I would have been able to save the money on aftermarket boots and kept the originals. I fell for the advice that new boots would solve the problem. My advice is if you have a lot of oil coming from the boots you should do the following:
1. Remove and thouroughly clean the IC boots, then watch for oil.
2. IF in a few months the oil has returned, do the CCV mod.
(All this assumes you do not have an oil leak from some other source!
Good luck.
Jack
jgarden is offline
post #7 of 8 (permalink) Old 03-01-2009, 11:25 PM
My Photos: (5)
Good luck.
it actually says if you have a loose boot or one with a HOLE in it,you can correct it with new boots.i was just saying if you have a damaged boot its an easy fix.
knock on wood....
4" exhaust no muff
post #8 of 8 (permalink) Old 03-02-2009, 06:24 PM
Mine intercooler boots were leaking and this worked for me - remove the boots and clean them and the surfaces they mount real well. Spray the contacting surfaces with hair spray - this will give it a tacky surface to keep it from leaking, but won't prevent you from removing it later. Reassemble and you're done. Mine haven't leaked since.
2001 X, PSD, 7" DR lift, 37" PJ Dirt Grips, Procomp Extreme Alloy wheels, 4.56 gears, Dynatrac Free-spin hub system, Diablo Predator , Banks 4" exhaust with Power Elbow, Kodiak Sidewinder steps, Autometer guages.
VX23Hokie is offline
