OIL LEAK FROM TRANNY - Page 2 - Diesel Forum - TheDieselStop.com
Old 01-11-2013, 03:32 PM   #16 (permalink)
put new seals in and still leaks. there is a trace of old 'yellow' o-ring could this be the source?? and how do get this out?
1999 f350 7.3 6spd; 243k miles no mods
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
tickedoff36 is offline   Reply With Quote
Old 01-11-2013, 03:55 PM   #17 (permalink)
RT
RT's Avatar
Brake cleaner and a toothbrush. Don't use your wife's.
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
RT is offline   Reply With Quote
Old 01-11-2013, 04:25 PM   #18 (permalink)
fortunately i am not married. and that would put you in the doghouse;OUTSIDE
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 01-11-2013, 06:50 PM   #19 (permalink)
i found out that the leak is in fact coming from my pedistal where it bolts to engine. how do you get it to seal?? are the new o-ring really thick? or is there a trick?
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 01-11-2013, 07:16 PM   #20 (permalink)
RT
RT's Avatar
No trick. Did you order new o-rings or just try to match diameters at the parts store?
Sent from my iPhone using AutoGuide.com App
Old 01-11-2013, 08:12 PM   #21 (permalink)
tried to match. is that the problem??
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 01-11-2013, 08:49 PM   #22 (permalink)
RT
RT's Avatar
Could be if the diameter was wrong.
Old 01-11-2013, 09:11 PM   #23 (permalink)
Transmission Fluid Level
Transmission fluid level when cold is slightly in the "H" hatched area; when hot engine running in "park" no fluid is on the stick when wiped down and reinserted? Any help is appreciated. No problem with shifting.
GAFN250 is offline   Reply With Quote
Old 01-11-2013, 09:23 PM   #24 (permalink)
my tranny is a 6sp manual NO DIPSTICK and besides found out it is pedistal.
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 01-11-2013, 09:29 PM   #25 (permalink)
diameter looked the same will order right ones as soon as i get paid anyone know where to get 'cheap' cartridge for the turbo? i am only going to change out the wheels and shaft for now.
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 01-13-2013, 09:27 PM   #26 (permalink)
WELL I FINNALY BROKE DOWN AND ORDERED THE RIGHT O-RINGS. SHOULD BE HERE BY WED. ORDERED FROM DIESEL ORING. ILL LET YOU ALL KNOW WHAT HAPPENS!!
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
Old 01-16-2013, 08:14 PM   #27 (permalink)
THESE GUYS AT DIESEL ORINGS ARE REALLY ON THE BALL. NICE!! I GOT 1 SET IN AND I SEE THE DIFFERANCE. I NOTICED THAT THE PEDISTAL HAS A GAP WHEN IT IS JUST SITTING THERE. B4 IT WAS FLUSH. I SHOULD KNOW THURSDAY IF I WILL BE BACK IN BUSSINESS OR NOT.
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
