OK...Whats the deal with this UVC wiring? - Diesel Forum - TheDieselStop.com
Old 08-31-2005, 12:20 AM   #1 (permalink)
Reading about some other people who've had trouble with the UVC wiring being loose, and the symptoms that have been mentioned sound identical to the problems I'm having on my early '99. I have found lots of posts from people saying they "fixed the uvc wiring" but nothing about how it's done or what the actual problem is! Is something loose? Are wires pinched? What's the deal? Whatever it is, I need to do it!
2000 F-350 Centurion CC/DRW/XLT/PSD/6spd/ESOF/4.10LS Wedgewood Blue/WD Chip/4 Straight Pipe/WD Gauges/Custom Frontend/J&J Grille, Boards & R-Bumper/Homemade EBV Brake, AIC & Ignition Bypass/Warn 12k Winch
99.0 F-350 SC/DRW/XLT/PSD/Auto/2wd Tourmaline Metallic/Stock for now!
WabbaStang is offline
Old 08-31-2005, 06:26 AM   #2 (permalink)
JimTJr's Avatar
My Photos: (20)
Re: OK...Whats the deal with this UVC wiring?
Your injectors/GP wireing goes THRU the valve cover gasket..(Actually part of the Gasket) Inside the wireing can get brittle..from heat. But there was a problem with the clips holding the plugs tight in the early years. If yours are loose and you have NOT BURNT up the plug already...then there are some little locks,,UVC LOCKS, the dealer will know what you mean. (Three plastic pieces...like 11.00) You only need two..guess one is if you loose one of them.... [img]/ubbthreads/images/graemlins/confused.gif[/img] or they felt guilty charging that much for two pieces... [img]/ubbthreads/images/graemlins/eek.gif[/img]
Anyway,,insert them into the harness,,and it will hold tighter.
But if you have been loose for a while,,you may have damaged the plugs..from arcing,,,there is 115v going to the injectors,,and pretty high amps to the GPs... do a really good visual of them.
The actual UVC harness is not too bad price wise...the gaskets are up there!!!!
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 08-31-2005, 02:16 PM   #3 (permalink)
OK thanks, makes more sense now. Sounds like the thing to do is check the connectors and see how they look, and try the clips first before tearing it all apart.
Anyone have a quick procedure on getting to these?? I have no idea where they are at
Old 08-31-2005, 02:34 PM   #4 (permalink)
streetdoc432's Avatar
The only way to check is to remove your valve cover...Do you know which side is messing up? Find someone with a IDM code reader, If it says #_ cylinder circuit open..even number cylinders are on the drivers side, odd # cylinders on the passenger side. Once you figure that part out, lay some carpet or padding across your engine, climb up on top of it, and make yourself comfortable. Take off your intercooler tubes and whatever else is blocking your access to the valve cover. Once you get the valve cover out of the way, the plug is right there in front of you, you can't miss it, it may be covered in oil, but it is really kind of simple to replace. R & R only took me about an hour and a half.
2003 Excursion Limited 4x4 7.3 PSD. Custom "Western Hauler" conversion. On board Firestone air bags. 4" stainless steel MagnaFlow exhaust with muffler delete, AFE Stage 2 intake, AutoMeter Ultralite 3 gauge pillar pod, DRV++,AIH plug,18K mod w/TAS, Superchips 1705 tuner,Zoodad mod,Transgo stage 2 shift kit, Kenwood 1000watt stereo-DVD with three screens. 6" Pro-Comp lift, 20" black XD Hoss wheels with 35" Nitto Terra Grappolers.
streetdoc432 is offline
Old 08-31-2005, 03:45 PM   #5 (permalink)
klhansen's Avatar
My Photos: (169)
My recommendation is to get replacement harnesses. The connectors themselves get brittle and will no longer hold them tight to the VC gasket. You may even break the connector trying to put the clips on (don't ask how I know this [img]/ubbthreads/images/graemlins/crazy.gif[/img]).
Retainer (Under Valve Cover Harness clips)
2C3Z-14A163-AB
Int’l 1844193C91
Wiring Harness, Injectors & glow plugs
F81Z-9D930-AB $50.15 (online ford parts place price)
Int’l 1830844C93 ~$25
One of the guys hot-glued the connector to the VC (I think it was the outside one, but if cleaned up well, that might work on the inside one also).
Hope that helps
Hard or no-start? Check Here
klhansen is offline
Old 08-31-2005, 04:59 PM   #6 (permalink)
OK stupid question but... Would an IDM code throw an SES light? Because so far we've never gotten a light but everything I've read of other people's problems points to the UVC stuff.
Also checked with local International dealer..
Clip kit: $8.22 (3)
Wiring harness $18.12 /each
Not too bad
So if you have to pull it apart to "really" check it out, is there another connector on the inside??
Old 08-31-2005, 05:38 PM   #7 (permalink)
JimTJr's Avatar
My Photos: (20)
There is ONE Main connector on the Under valve cover (UVC) harness...it has 8 other connectors on it...4 to the injectors and 4 to the glow plugs. The gasket has two connecting points on it...inside the VC and outside,,the one you can see in the valley of the motor..(If you lean over and look hard..lol) Then the engine harness connects to the gasket. I would check allllll connections of course. Look for burnt pins..melted plastic, ect...
Neither one of the valve covers are that hard to remove,,the passenger side is more intimidating,,,but not that bad really.
JimTJr is offline
Old 08-31-2005, 08:26 PM   #8 (permalink)
klhansen's Avatar
My Photos: (169)
An unplugged injector WILL light the SES and throw the P1316 and P127X codes. Not sure if an intermittent problem would do that, but it will still throw the code. Maybe the SES isn't on long enough for you to notice it.
Clip kit: $8.22 (3)
Not too bad
Good prices - wish we could do that good up here (the good ol' Alaska Gouge [img]/ubbthreads/images/graemlins/frown.gif[/img])
What Jim said.
klhansen is offline
Old 09-01-2005, 04:59 AM   #9 (permalink)
Well, thanks to the help I went and changed both harnesses tonight, not that big of a deal if you just take your time like anything else. Runs better so I suspect that the old stuff had seen better days. So far no more dropping idle and noticable smoother.
Still shakes like hell right about 38mph when it hits lock up!! Argh. Tranny is smooth in all other gears...Torque converter time?
Old 09-01-2005, 06:14 AM   #10 (permalink)
JimTJr's Avatar
My Photos: (20)
Sounds like some kind of tranny issue..TC or otherwise. I LOVE MY BTS!
If yours fails tooo bad your way out west there,,,, but he SHIPS!
Glad you got the other issue figured out.
JimTJr is offline
Old 09-01-2005, 09:46 PM   #11 (permalink)
JF
Clip kit: $8.22 (3)
Not too bad
Anyone have the International part numbers for the harness and/or pigtails from the outside of the valve cover to the 40 pin connector?
John Fisher
Poway, CA
99.5 F250 Supercab 4x4, 6" Skyjacker 315's, custom Callen Camper, Reunel rear bumper, Diesel Innovations Stage 2's, John Wood transmission; 74 Bronco 351W C-4 etc...
JF is offline
Old 09-02-2005, 02:23 AM   #12 (permalink)
klhansen's Avatar
My Photos: (169)
VC connector to 40 pin (actually 42 pin) is the whole engine harness. Many $$$ [img]/ubbthreads/images/graemlins/eek.gif[/img]
Try a PM to Dave1957. He gave me some numbers for other repair pigtails, but not the VC outside connector one. Maybe he can track it down for you.
klhansen is offline
Old 09-02-2005, 12:35 PM   #13 (permalink)
My Photos: (31)
If yours was like mine, and the locking mechanism of the clip broke, try zip tying the connector to the CCV housing on the valve cover. A couple of large black ties connected together works very well.
Also, don't be afraid of asking the parts or service manager if they have any "bad" harnesses around. Often they are not that bad and have nice connectors. I got some 42 pin connectors for free from a Lincoln Mercury dealership.
Hope this helps.
Early 99 F250 CC PSD, 6-Spd, 4x4, DP Tuner 4 Pos Chip, 4 BD Cat Back, Cat Delete, 3.5 Down Pipe, CCV Mod - Subman Style, ITP Fuel Sys, Dahl Fuel Filter, Home-made Headache Rack, Coolant Filter
64 Falcon Convertible
289 4-Speed 9"
Fat Diesel is offline
Old 09-02-2005, 03:31 PM   #14 (permalink)
If you retainer fingers are not broke, I have what I think is a perfect fix.
Cut a peice of 20 guage sheet metal, ( I used Staimless Steel [img]/ubbthreads/images/graemlins/biggrin.gif[/img] ) into a rectangle of 1" X 3/4".
Push the plug back into position then slip this wafer between the plug and the clips. Snugs it all back up and holds the locking fingers into position.
With the rocker cover in place the wafer is totally encapsulated and cannot move.
I was afraid of any other mods due to the possibility of something coming loose or disolving in the oil. [img]/ubbthreads/images/graemlins/eek.gif[/img]
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
99 F450 PSD FWD 4:88 final drive Detroit Locker on the rear 16' aluminum bed Ezyloader 16' articulated hive crane. Otherwise BONE STOCK!
miteyvictor is offline
