The old "Seafoam in the fuel bowl" trick ?? - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By klhansen
post #1 of 6 (permalink) Old 02-16-2017, 11:04 PM Thread Starter
Just replaced my fuel filter and was considering filling the fuel bowl with Seafoam prior to the first start up as has been mentioned here and elsewhere for its supposed injector cleaning abilities.
....Anybody know if there's a downside to this? Other than the money spent on the Seafoam are there any potential bad outcomes?
Thanks.
1999 F350 DRW Long Bed Crew Cab 4x4, Purchased "new" in 2008 w/ 59k miles.
Carries 5000lb+ Lance Camper
DP Tuner chip w/ 60econ, 120race, decel, hi idle and old SuperChip Boost Tube still installed.
VDO gauges
Ford AIS Extreme Duty air filter and zoodad mod
MagnaFlow 4" Exhaust and muffler
John Wood Eco HD transmission. 6.0 cooler and Maghytec tranny pan
Maghytec rear diff cover w/ Mobil 1 75W-140
Mobil 1 ATF in trans/transfer case/powersteering Magnafine filters for tranny and power steering Airbags, Rancho RS9000XL shocks, Torklift Swaystops
Crank case ventilation mod
TransferFlow 57 gallon fuel tank
Riffraff fuel and oil crossover mod
Strictly Diesel fuel tank/pre-pump kit mod
From Dieselsite: 1)air intake heater delete 2)max A/C assist 3)braided 4WD shift hoses 4)replacement boots for all turbo/intercooler boots 5)coolant filtration system 6)203*F thermostat
2 layers Dynamat Extreme on interior roof/floor/doors, Dynamat Xorb on Firewall
Alpine IVA1000 and amp, Python Alarm
farnorthdriver is online now
post #2 of 6 (permalink) Old 02-16-2017, 11:32 PM
losfinch's Avatar
I've done it on a number of occasions without any problems at all....315,000 and purrs like a kitten...a loud kitten anyway.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny, 26 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Donaldson ELF7405 oil filter, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
post #3 of 6 (permalink) Old 02-17-2017, 12:27 AM
klhansen's Avatar
My Photos: (180)
I've done it once or twice as well. No ill effects really possible. It's just a different kind of fuel, and the engine will burn it just fine.
Greg687 likes this.
), AIS,
regulated return,
klhansen is offline
post #4 of 6 (permalink) Old 02-17-2017, 12:20 PM Thread Starter
Hi KL, Might you know the fuel flow rate of our engine at idle? Would like to start it and run it just long enough to get the Seafoam into the rails and injectors and then shut the engine off and let the Seafoam "sit" there a little while.
Run it too long and the Seafoam is burned and normal diesel fuel is in the rails and injectors; run it too short and the Seafoam doesn't get to the rails/injectors.
Thanks.
VDO gauges
post #5 of 6 (permalink) Old 02-17-2017, 01:21 PM
klhansen's Avatar
My Photos: (180)
Thanks.
Don't know for sure, but I would guess idling it for just a couple of minutes should do the trick. Some of the Seafoam will go out the return line to the tank and get replaced by diesel coming into the filter housing, so it gets diluted a bit from the get go. Not a bad idea to let the concentrated (as much as possible) Seafoam sit in the fuel system inside the block and injectors. Another approach would be to pull the inlet hose from the fuel pump, stick a hose into a jug of Seafoam as well as fill the filter with it, then run it just until that jug is sucked dry by the fuel pump.
), AIS,
regulated return,
klhansen is offline
post #6 of 6 (permalink) Old Yesterday, 10:05 AM
Torque says my truck uses a little over 1gal/hour at idle
2003 F250 crew, 4x4, 7.3 d with Donaldson CAI, SCT tuner with DP 80ECONO and 60TOW tunes, HPX, Hutch mod, in-line fuel filter, 2" lift, extended air dam mod, WW2 turbo wheel, running Torque Pro
Greg687 is offline
