Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 10-12-2009, 07:47 PM   #1 (permalink)
txfxl's Avatar
Question opti-lube XPD?
anybody using this additive? i think we all saw it did well on that wear test that has been going around;
http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
just looking for some folks who have used it and found it quieted down their motor and didn't do anything catastrophic
2000 F250 ext cab 8' Bed, 4x4, AFE Stage II, Warn Premium Locking Hubs, MBRP 4" Turbo Back, 3 Gauge Pillar (Turbo, Pyro, Trans), Racor CCV Filter, AIH Delete With Code Fooler, Wicked Wheel, Oil Crossover Line, Coolant Filter, 203* Thermostat, Stancor GPR, Under Hood Fuel Pressure Gauge, DB Starter, ITP In-Tank Mod, Peripheral Ipod Direct Connect
Chip and a valve body in the overtime funded near future
txfxl is offline
Old 10-13-2009, 01:08 PM   #2 (permalink)
txfxl's Avatar
man, nobody has tried this stuff?
txfxl is offline
Old 10-13-2009, 02:38 PM   #3 (permalink)
Supporting Member
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
not really, don't use additives, but it is good to know and save the webpage.
Thanks for sharing!
Adrian
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
Wicked Wheel
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using SCT 100hp Performance tune.
Wastegate disconnected for now...
2005 front clip.
Train horns.
Zoodad mod.
CFM-plus
CCV rerouted
S&B CAI
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Camera,DVD,Nav.,Satelite Music.
Jason smooth topper.
Here but not installed: 4'' Ported Housing,ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.,TRU Cool tranny cooler (no time )
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 10-13-2009, 03:28 PM   #4 (permalink)
I use the Opti-Lube Summer stuff just for added lubrication. Costs about $50/gal but will last for 15k-30k miles depending on the ratio I use. Hopefully cheap insurance for lubrication........provided those lubrication tests are accurate. If not........oh well, I'm out $50.
2001 F-350 Crew Cab XLT PSD 4x4, Long Bed, 6-speed, 3.73, Manual Transfer, Power TTT Mirrors, 122k miles.
1989 Toyota 4x4 xtracab SR5 V6, Beat to heck with 200k+ miles and still running strong.
catch&release is offline
Old 10-13-2009, 06:36 PM   #5 (permalink)
txfxl's Avatar
yea looks like its on sale on their site right now too
txfxl is offline
Old 10-14-2009, 05:52 AM   #6 (permalink)
I've been using a half ounce per gallon of Walmart 2-cycle ashless.
It has quieted the old 1996 7.3.
It did well in the famous test.
Ten bucks per gallon.
Makes me feel good.
MichaelPatrick is offline
Old 11-03-2009, 03:17 PM   #7 (permalink)
Just saw this thread and thought I would share another website that has Opti-lube products, looks like they are having a sale on the summer blend quarts.
Grace Distributing: Opti-Lube
I use the summer blend because it is cheaper and a better lubricator than the wally world stuff, I also use the Oil Fortifier and have noticed a lot quieter and smoother running engine.
Largecar
LargeCar is offline
Old 11-03-2009, 09:42 PM   #8 (permalink)
bigb's Avatar
I plan to start using it, I already have several gallons in my shop. First I need to use up my Stanadyne Performance Formula, I am thinking about using both the Stanadyne & the Opti Lube XPD both, just to use up the Stanadyne.
Did you notice on the test that Bio was at the top of the list for lubricity, and what a tiny percent it took? I have a Safeway near the house that sells B-20, which I could use with the Stanadyne.
My last tank was mixed with bio for about a 5% total, plus the additive Ford sells at the parts counter. My engine got SUPER quiet, people have even commented on it.
Haven't done any MPG tests yet.
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 133K, AIS, Isspro pyro, boost & tranny temp pillar pod, Dieselsite coolant & tranny filters, ITP pre pump tank mod, netbook mount with AE.
bigb is offline
Old 11-03-2009, 10:11 PM   #9 (permalink)
DHTD's Avatar
I love Bio, even in the small 5% amount, it feels like the mileage is better, the engine runs nice and smooth and is waaaaay quieter. I make small batches, time to go collect more WVO as I ran out and missing it! It is night and day difference sound and power wise when you have to fill up with #2, even dumping your oil change into the tank helps dramatically power and sound wise. Just my observation with the truck.
01' 7.3 4X4 DRK MTLC BLU, DP Tuner 60T-80E-120R, AEM Intake, 4" Turboback Silverline Exhaust, BTS VB, Lance Camper, CCV mod, Rebuilt Injectors, In-Tank Mods, 203T, 6.0 Trans Cooler, 175,000K and original tranny, so far so good.
DHTD is offline
Old 11-03-2009, 10:16 PM   #10 (permalink)
bigb's Avatar
The only Bio I have ever run is made & refined commercially with soybean oil. I would be hesitant to run WVO and WMO in my engine with 2K for injectors. Maybe in my old Mercedes 300, but not in my baby!
bigb is offline
Old 11-04-2009, 11:17 AM   #11 (permalink)
I know for a fact that BD has way fewer BTU's the Diesel so the engine puts out less HP therefore it stands to reason that mileage is also reduced.
Dumping filthy gritty carbon laden oil into a fuel system I painstakingly try to keep clean using the occassional tank of BD or Seafoam is one thing I am not going to do.
2OOO F-250 4WD Crew Cab, 223,000K miles, replaced brakes, #1 injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella T, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
PRDATR is offline
Old 11-04-2009, 05:49 PM   #12 (permalink)
aklim's Avatar
Anything scientific besides SOTP? Even Bio producers will tell you that you will lose mileage with their stuff because it has less BTU.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, Van Turbo and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 11-04-2009, 05:51 PM   #13 (permalink)
aklim's Avatar
Bosch suggested that the difference between D2 and what the manufacturers want MIGHT lower your lifespan by maybe 10%. Is it worth it for me to go calculate the ratios, buy the stuff and carry a jug around? I don't think so.
aklim is offline
Old 11-04-2009, 08:57 PM   #14 (permalink)
DHTD's Avatar
Well I said it "feels" like mileage is better, I didnt say it was in fact better.
I dont run WVO even in small increments. I havent had a problem running my oil change oil and filling up my tank afterwards.
In fact my injectors love the stuff,biodiesel and WMO(from my own truck) I dont hear my injectors clanking around running either. When I dont have either around...I run 2 stroke ashless. All work great!
I have 2 fuel filters FYI, do as you will,I could care less what you guys do or tell me not to do, Im just stating what I do, maybe I will feel differently with 2grand in injectors but then again probably not because I would just get a kit from DIY.
DHTD is offline
Old 11-04-2009, 09:12 PM   #15 (permalink)
aklim's Avatar
Guess I don't know how to feel the mileage is better. I know how to compute and that tells me if the mileage is better. Still, like I said, even the bio peddlers will admit it has less BTU and therefore less power and mileage as compared to D2 so I don't know how that can be more than a placebo effect.
Bio changes the combustion noise. I am curious as to how you can sit in the truck and hear the injector noise above the engine noise without sophisticated sound filters. Bio has a difference cetane and that does affect the combustion. When I had the regulated return, the engine became quieter. What changed besides the ignition noise from #8 getting the fuel it should have?
aklim is offline
