Just ordered my AIS, smoking deal. At same time I am going to replace my batteries (Phoenix and the heat you know). Whats the story on the Optimas and the bracket I need to make sure I get?
Also, with batteries out want to go with brighter headlamp bulb. No harness upgrades just the brighter bulb. Whats up with that, too?
Scott
MMC/ss Retired - Still bound by my oath to Protect and Defend the Constitution from all enemies foriegn and DOMESTIC
NRA Life Member
03 F-250, Auto, CC/SB, 3.73LS, XLT FX4, Tiejtan Front Replacement, Ruenel Rear Bumper, Rancho Leveling Kit, Airbags, Dynatrac Free Spin / Warn Hubs, Dynatrac Front Dif cover, Tire Gate, Mag-Hytec Rear Diff, 46 gallon tank, Cryo Treated Rooters and Steel Braided Brake Lines, 203 T Stat and Billet housing, Marinco, Auto Meter: EGT, Boost and Tranny, 4" SS Turbo Back, pre pump and regulated return; HP X, AIS, AIH Delete, Banks IC, DP Tuner - 60 HP Daily / 80 HP Tow (both no codes) and the best for last - BTS with 6.0 cooler!
The bracket should be taped to the top of the battery. Make sure you get the 34/78's with 980 CCA's. Once you put the brighter bulbs in you'll be buying the harness. I did. Going to put the harness in today. This will get you alternator voltage, instead of 11+-. Then they'll be bright.
Make sure you have a fire extinguisher in the truck. You will need it eventually.
Look at the contacts on your headlight - the electrical conductors that actually carry the current, then look at the factory headlight wiring (16ga?) and then decide if you want to pull more current through this crappy setup.
I wouldnt. I did, on my 00, and it nearly fried the whole connector assy. Melted the potting compund used in the headlight connector and burnt the harness pigtain connector.
[/ QUOTE ]Denis:
Don't know where you came up with those specs. According to the Optima Batteries website The 34/78s are 800 CCA not 980.
Scott:
I personally would not put in a higher wattage bulb without heavier wire harness. As stated above, a heavier gauge harness will deliver the 14+ volts to the bulbs and the difference between 12 and 14 is nearly night and day!
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
Got the numbers right off the top of the batteries in my truck. But it's 980CA's and 800CCA's. Sooooooooorry, Guess the age is affecting the short term memory [img]/ubbthreads/images/graemlins/crazy.gif[/img]...What was the question??? [img]/ubbthreads/images/graemlins/smile.gif[/img]
-------------------------------------------------- 2000 F350 SD 4X4 CC LB Lariat
4"DPPI Turbo back
aFe Magnum
50/80/110 Bill's flip chip W/PMT1,and a DP 120
A-Pillar Autolites Trans/EGT/Boost-GOS Racing
APCM(AIC)
Boost Bleed off
4" Lift W/315's
Dual alt's.
ATS housing
Wicked Wheel
Banks 1.0 A/R housing
ISSPRO TTM
Warn Premium Hubs
J/S IDM
Racor 4500 CCV
ARG SuperPump and Gear
GOS Racing-Head Light Harness 2004 Sprinter 292FWRLS SOLD: 97 F250HD CC SB 4X4 7.3L E4OD 4.10
