P0107 code - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 03-25-2007, 07:21 PM Thread Starter
P0107 code
This morning I ran my sc 1705 and read a P0107 code and it reads: Manf Abs Pres/Baro Pres Circ Low Input. [img]/ubbthreads/images/graemlins/shrug.gif[/img] What does this mean and is it serious?
2001 PSD F-250 longbed single cab, factory pipe ( muffler & cat delete), SuperChip Programer, quadzilla monitor, M.A.C. cold air intake
ghillieman05 is offline
post #2 of 6 (permalink) Old 03-25-2007, 08:09 PM
fordmastertech's Avatar
Re: P0107 code
Is it serous who knows. Its a BARO code and to fix it you will more than likely need to replace the PCM. I would put the stock program in it and see if the code returns.
Fords description
The barometric pressure (BARO) sensor is a variable capacitance sensor used to determine altitude. Prior to 99-1/2 M.Y., the BARO was remote mounted under the instrument cluster. It is now internal to the Powertrain Control Module (PCM). The BARO sensor cannot be serviced separately. PCM replacement is required if a failure is identified.
Timing Control The BARO signal affects injection timing and fuel quantity to optimize engine operation and control smoke throughout all altitude conditions.
Glow Plug Control The BARO signal is one of the variables used to calculate glow plug ON time. At higher altitudes glow plug on time is increased to reduce start-up smoke.
Detection/Management
A BARO signal that is detected out of range high or low by the PCM will cause the PCM to ignore the BARO signal and use the manifold absolute pressure (MAP) signal generated at low idle as an indication of barometric pressure.
FMT
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
post #3 of 6 (permalink) Old 03-26-2007, 06:44 PM Thread Starter
Re: P0107 code
sorry but could you translate in english. lol I'm new here to the diesel thing and some times I get lost when you guys get to talking.
post #4 of 6 (permalink) Old 03-26-2007, 07:03 PM
Re: P0107 code
PCM = Powertrain Control Module.
FMT
post #5 of 6 (permalink) Old 03-26-2007, 07:38 PM
Re: P0107 code
[/ QUOTE ]If it is running OK & not smoking too much You should be OK. Do you have any sympoms?
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #6 of 6 (permalink) Old 03-26-2007, 09:00 PM Thread Starter
Re: P0107 code
well i have had my programer on setting three for about 4 days and I have noticed a rough idle when cold. It also smokes good in setting three , but I thought that was normal? In setting two it does'nt have a rough cold idle. Could this be related. You think I just aught to leave it out of setting three?
