P0605 - Diesel Forum - TheDieselStop.com
Old 12-30-2008, 10:09 AM   #1 (permalink)
P0605
The truck is at the garage, they gave me a list of codes the truck threw - that one "ROM error" seems to be the worst of them. another is saying the #7 injector isn't firing... same injector another shop had replaced.
can anyone tell me if that code is something that can be re-flashed by a dealer, or and I SOL and need a new computer?
1999 F-450 crew cab DRW, 6spd. 4" straight exhaust, AFE high flow filter, zoodad, ISSPRO guage set, EBPV delete, CCV mod, DPTuner 80 econo, Wicked Wheel, Midwest Transmission Short Shift Kit
2004 F-150 reg. cab - bagged, shaved, and completely rid of all chrome. street queen.
Hawker is offline
Old 12-30-2008, 12:58 PM   #2 (permalink)
Bill1013's Avatar
If the #7 isn't firing and it's been changed, I would be looking at the UVC harness or plug connection on that side. Requires removing the valve cover on pass side.
What problem is the P0605 code (ROM error) causing ? Did you have that code previously to changing the #7 ?
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
Old 12-30-2008, 01:14 PM   #3 (permalink)
never did a diagnostic before the injector was changed, just the contribution test.
i've read that the chip may throw the ROM code, which makes sense. the truck ran beautiful when i first put the chip in, no engine light or anything.
I changed the ICP about 2 weeks ago, and i'm looking at the list and theres a bunch of ICP codes:
P1209 - ICP Peak fault
P1212 ICP voltage
P1211 ICP not controllable
P0605 ROM error
P1277 #7 cylinder open
P0475 Exaust pressure control valve malfunction
Hawker is offline
