The uvch looked good. I did not see any burned pins, cracked wires or loose caps. klhanson< I did follow your information for hard start link and that helped. I got ohm readings of .2-.4 on all glow plugs at the connector on the outside of the valve cover. that is why I thought it may be the gpcm might be the culprit. the p0683 code is not the code for the opposite head. I think it said "open circuit" or something. I appreciate any help or information.
Also, whoever posted the tip for using a piece of tubing to remove the glow plug. thanks. I used a 1 foot piece of gas line from a motorcycle to slip over the tip of the glow plug to remove, insert, and start threading the gp. It would be too easy to loose one down a hole if using a pliers. by the way. 165,000 miles on the truck now.
2000 f-250 crew cab, long bed,4x4. 6-speed manual. fumoto valve, reese tow boss receiver. 170,000 miles
Reason: change
