Pan Sylicone leaking again - Diesel Forum - TheDieselStop.com
Old 11-18-2009, 11:40 PM   #1 (permalink)
Took the truck to the dealer today with an oil leak in the front of the engine. Now this is the third time the truck has leaked after another dealer fixed the dip stick problem. Dealer charged $80.00 to tell me that I had a leak thru the silicone at the pan and wanted $1,500 to fix it. The truck was last fixed (?) on 21 Jul 09 at a different dealer. He said no warranty on the silicone or the workmanship of the other dealer. How about that - Ford stands behind their product up to a point. Any options besides welding the pan to the block? I'll call the other dealer tomorrow to see what he can do for me, but I don't expect much. As noted in my sig. we are full-time RVers and spend 6 to 8 months on the road each year.
2000 White F550 PSD CC, Cabriolet Body, Firestone Air-Ride Suspension, 33.8G Aux Fuel Tank, 3 Pod A-Pillar gauges. TTT mirrors, US Gear D-Celerator, Pre-Pump/In-Tank Mod with Racor 645R30, 203° T-Stat/Bullet Housing, Fleetrite ELC w/filter, SunCoast Tranny w/3 disk TC, Mag-Hytec tran pan, and 6.0 Tran cooler, AIS Air Filter, AIH Plug, CCV Mod, SS HPX, Zoo-Dad, Trailer Saver II Air Suspension Hitch, Brake Smart Controller. Towing a HitchHiker 35.5' LKTG Premier at 16,360#.
RichZ is offline
Old 11-19-2009, 08:08 AM   #2 (permalink)
well you could do what a stealership did to me! i call it the gresham smear. took the truck in for a leaking oil pan. they told me that they pulled the engine and resealed the oil pan. paid the $ and went on my way. come to find out they only smeared rtv over the edge of the oil pan and the engine block. this worked for a little while. took it back! threw a fit! this time they did pull the engine and resealed it, then they put hose clamps that were 10 times to big. went on my way again, blew a radator hose off. great work the stealerships do, so what im saying is if they do pull the engine and do the work i would highly recomend that you clime all over the truck to make sure they really did pull the engine and put it back together correctly.
a man is only as good as his word
2000 f250, 4x4, PSD, auto, XC, LB bradford built flatbed, edge juice with attitude, 4"BANKS exhaust with BANKS jake brake, BANKS Trans command, BANKS big head wastgate, BANKS turbine housing, BANKS intercooler, k&n air filter kit,ATS ported shroud compressor housing with WW, CFM+ intake manifold,AIH delete,ITP overboost annihilator
1983 f250 6.9, STC, 4X4, 5 speed, LB bradford built flatbed,with BANKS sidewinder turbo kit, BANKS 4" exhaust injectors set at 2150psi
1970 f250 FARM AND RANCH SPECIAL
djbrown is offline
Old 11-19-2009, 08:32 AM   #3 (permalink)
dlblazer's Avatar
The correct way to fix leaking pan sealant is to pull the engine. $1500 is a good price compared to what some have paid. Any other method will be sub-standard and leave you wondering when it will leak again.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter (no more), Superchips 1705 tuner, Reese Titan, AIS, IPT pre-pump filter kit, in-tank mods, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
dlblazer is offline
Old 11-19-2009, 11:07 AM   #4 (permalink)
bugman's Avatar
My Photos: (18)
Just an FYI if a different dealer did the pan leak back in July and it wasn't under warranty then "FORD" did not do it but Joe Blow Ford did the work. If you want any warranty you would need to go back to Joe Blow Ford to have it done and not any other dealer.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 11-19-2009, 11:41 PM   #5 (permalink)
Bugman - you are right to a point. The first dealer charged me to pull the motor and fix the dip stick leak. I don't think the second dealer was paid by Ford but did the work at no charge(11 months, 21 days). The third dealer was not paid by Ford and changed the pan at no cost to me (12 days). Now the fourth dealer will not touch the truck without being paid to fix the leak (3 months, 19 days). I called the third dealer and the Shop Foreman said to bring the truck back and he will call a Ford Rep to examine the motor to see why it won't seal. I'll only have to drive 689 miles and spend some time in a motel while waiting for the truck. So now I'm weighing the cost of having it fixed here in Mesa, AZ or spend the time and money taking it back to dealer number three. I guess the one year parts and labor guarantee is not transferable from dealer to dealer.
RichZ is offline
