paperboard / plastic guard under front bumper - is it important? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 08-15-2009, 03:53 PM Thread Starter
Question paperboard / plastic guard under front bumper - is it important?
There is a flexable guard of sorts that goes under the front bumper to under the radiator housing. The gromet holes where the plastic pop rivits hold it on are torn out and now it just hangs down.
My question is, Is this piece important enough to replace? What purpose does it serve?
I don't know what it's called but I can't seem to find it in any of the parts catalogs.
Thanks guys!
Lisa
'99 F250 Super duty
Crew Cab short bed.
farmmom39 is offline
post #2 of 8 (permalink) Old 08-15-2009, 03:59 PM
chuckster57's Avatar
Most of the pieces that are put on are there for directing air movement. I do know that some pieces are considered critical for cooling. I can't say that it's the case here. Personaly I would try to re attach it.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 8 (permalink) Old 08-15-2009, 04:53 PM Thread Starter
I already tried to reattach it but it's too torn. It also isn't big enough to stretch it and poke new holes. It is torn loose from the 3 retaining clips that hold it to the front bumber and it looks like it will fail soon from the back (bottom of radiator housing) and be completely off.
I keep looking at it and it doesn't look like an air foil, it seems to be more of a protector for the little square heat exchanger that sits at the bottom front of the radiator.
Anyone tell me what the little radiator / heat exchanger is? It's only about the size of my hand.
http://www.thedieselstop.com/forums/...1&d=1250374151
post #4 of 8 (permalink) Old 08-15-2009, 05:37 PM
If the front edge used to attach to the bumper then your probably right. The little cooler is for your Power steering fluid I think. You might be able to get a new one form the dealer, Probably called a "skid plate" , or fabricate a new piece to protect the cooler.
Train Horns:
post #5 of 8 (permalink) Old 08-16-2009, 05:20 PM
firemediceric's Avatar
I'm in the same spot as you were the one on my truck just started hanging down, too.
I think the piece may make for a little more aerodynamic air flow, but I don't know. One reason I would like to keep it in place is for a minimal amount of protection from road debris that it may offer for the coolers.
If you price a replacement, plz share what you find.
1999 7.3 F-350 and 2004 6.0 Excursion
Truck: Tymar type intake, Zoo Dad, muffler delete, By-pass coolant filter, Dahl 100 fuel filter Harpoon & Hutch mod, upgrade to 3/8" fuel line and HP oil X-over, Oil by-pass, Scan gauge II.
Excursion: All stock, so far.
firemediceric is offline
post #6 of 8 (permalink) Old 08-17-2009, 08:37 AM
The small cooler is for power steering. The rubber deflector not only protects the lower portion of the a/c condensor and the powersteering cooler but also keeps the air directed through the entire line of coolers.
2000 f-350 crewcab long box SRW 250,000 k 5" BDS lift 35" toyo's. Isspro gauges. 6.0 tranny cooler. zoodad. 203 t-stat. Ais. warn lockouts. Stancor gpr. rr Billet plenums. rr Billet compressor wheel. rr Hiflow fuel fittings. rr Ocr. rr Boot set. barder 360. Non Ebpv pedestal. hiflow outlet. Hiflow banjo bolts. 4" mbrp turbo back. IH bellowed up pipes ceramic coated.
trocustoms is offline
post #7 of 8 (permalink) Old 11-11-2013, 09:50 AM
Radiator Air Deflector
Need Help Finding a Part?
I realize this is a very old thread, but I needed the same part and there was no follow-up, so here it is, for those that need the answer.
Part Name: Radiator Air Deflector
Brand: Ford Genuine Parts
Part Number: 8327
Price: $37.95
Quantity:
+Add To Cart
ShareThis
Part Description: With A/C; Lower front - flat hard rubber piece that mounts with seven push pins to the bottom of core support
Quantity Per Vehicle: 1
Package Quantity: 1
lenndeb is offline
post #8 of 8 (permalink) Old 11-11-2013, 11:27 AM
Flywheel's Avatar
It keeps the air coming in through the bumper from simply diverting down and out and bypassing the coolers.
I have not had one on the farm truck for a long time - but have always wanted to but a piece of steel stock there....
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
