Part # F6TZ-9F838-A - Diesel Forum - TheDieselStop.com
Old 03-03-2007, 10:58 PM   #1 (permalink)
Part # F6TZ-9F838-A
Is this an EBPV sensor? If not, anyone know what part it is?
IBUILD is offline
Old 03-03-2007, 11:02 PM   #2 (permalink)
My Photos: (9)
Re: Part # F6TZ-9F838-A
it is the icp sensor
(mine) 94 7.3 IDI non-turbo XL 350 super cab long bed
autojet y pipe and a stock p-stroke exhaust on the end of it 25xxxx miles, amsoil bypass, coolant filter, 08 Diff cover
(dads) 02 350 7.3 powerstroke crew cab 4x4 ESOF
mods: itp in tank/prepump, 4 inch exhaust, ats housing, High flow outlet, trans, pyro, boost gauges, DP Chip, 6.0 transmission cooler, 6.0 Banks "technicooler" intercooler 150 bucks , coolant filter, amsoil bypass, 08 diff cover "OEIS", b&w 5th wheel companion
21xxxx mileshttp://photos.thedieselstop.com/show...0/ppuser/46897
WHY THE HELL SHOULD I HAVE TO PUSH 1 FOR ENGLISH?
H O N D A - How Odd No Damn Acceleration
radeon1314 is offline
Old 03-03-2007, 11:03 PM   #3 (permalink)
ICP Sensor is what the base 9F838 shows. 9J460 is the base for the EBP sensor.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
My Truck
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
Old 03-03-2007, 11:27 PM   #4 (permalink)
Thanks, guys. Any idea what they cost?
IBUILD is offline
Old 03-03-2007, 11:31 PM   #5 (permalink)
Last I remember, over $100 for either at the dealer, not sure how much at International. If you can wait, there are usually several on E-Bay for a lot less than the dealer or International.
Buddy
My Truck
Old 03-04-2007, 02:37 AM   #6 (permalink)
Banned
179 bucks here at your friendly ford dealer here in town.
kainers is offline
Old 03-04-2007, 04:06 AM   #7 (permalink)
I paid $33.78 plus shipping for a new ICP (Injection Control Pressure Sensor) in a sealed Ford package from eBay as a spare about 6 months ago.
Jim
2000 F250 SD Lariat, SC, SB, 4x4, 7.3L PSD, 6-Spd ZF, 8,800 GVWR, 20,000 GCVW, Reese Class-V Tow Beast Receiver Hitch, Prodigy V2.6, 4" MBRP Stainless Steel Exhaust, AIS Induction Air Filter, AutoEnginuity
2002 26' FT2200 Weekend Warrior Toy Hauler, 102" Wide-Body, 11,100 GVWR, Reese Titan 14,000 lb Trunnion Heavy Duty WD Hitch, DC HP Sway Ctrl, Onan 4BGE-P Emerald Plus GenSet
jlrsn is offline
Old 03-04-2007, 09:30 PM   #8 (permalink)
KF6ZVT's Avatar
I paid $108 for an ICP from International about a year ago.
Ford was asking $176!!!!!
2001 F250 SC 4X4 Blue PSD Auto, Cody Gooseneck Hitch, Rancho Shocks and Steering Stabilzer, Tekonsha Prodigy Controller, Garmin Streetpilot 2610 GPS, Walker BTM, 285/75R/16E, Western Diesel Trans-Pyro-Boost, Pillar Mount, Painless fuse panel, In-tank and Pre-pump mods, Slotted Rear Rotors, Slotted and Cross Drilled Front Rotors, Fumoto Valve, Zoodad Mod, Transfer Flow 46 gal tank, Mag-Hytec Differential Cover, Electric Tailgate Lock, IAH Deleted, Coolant Filter, DP-Tuner 80 hp PCM, CCV Mod, 203 Thermostat, Ford AIS Air Filter
KF6ZVT is offline
Old 10-03-2009, 10:58 PM   #9 (permalink)
Thumbs down ICP Sensor
I just paid $310.97 for this part at George Stockfish Ford Sales in , North Bay Ontario. These guys need to be reported for stealing...if you can buy this same part on E-Bay for $39.99 dollars
whipper722 is offline
Old 11-20-2009, 12:05 PM   #10 (permalink)
Yep, price gouging is a glorious trait of some. Got one off ebay aweek ago $41 and change
geoffcoxnz is offline
Old 11-20-2009, 12:46 PM   #11 (permalink)
boomboom's Avatar
There is a couple of EBP sensors on ebay now for $89.00 Type in 7.3 powerstroke sensors on ebay. If you look under just powerstroke sensors there are a couple of 6.0 sensors for 46.00 so watch out not to get wrong one OR are they the same sensor for both 7.3 and 6.0 ?
boomboom is offline
Old 04-07-2011, 08:02 PM   #12 (permalink)
I need to install an ICP sensor in my 2000 F350 7.3. Does anyone know where it is located on this truck.
duallyman77 is offline
Old 04-07-2011, 08:53 PM   #13 (permalink)
klhansen's Avatar
My Photos: (169)
According to what Tom told you on your other thread (and I agree with him), you don't need a new ICP sensor.
But FYI, it's located here:
Hard or no-start? Check Here
klhansen is offline
Old 04-09-2011, 06:30 PM   #14 (permalink)
Valve Cover
I pulled the left valve cover off and the connector was not loose nor tight. It did come apart with eaze. There was alot of oil in the connector. Gasket seems fine. Now do I clean it up and put it back together or what. By the way that VC was no easy task.
Old 04-09-2011, 06:47 PM   #15 (permalink)
tinman13kup's Avatar
I would keep posting in your original post, to keep the info together. The VC gasket has wires that go from one side to the other, and are just pinched into the pins on the connectors. It is very possible those connections have gone bad, and seeing as there is a coating on them you wouldn't see them. You should re-connect all the connectors and start the truck without the VC on. Look for oil coming out the top of each injector, which indicates it is firing. Oil coming from the base indicates a bad o-ring.
Tom
99.5 PS CC 4x4 SRW ZF-6
- AKA "The Big White Truck"
tinman13kup is offline
