Parts - Diesel Forum - TheDieselStop.com
Old 07-03-2009, 05:57 PM   #1 (permalink)
Parts
Can you buy ford parts at a International Dealer? Can you just tell them what you need and they cross it over?
Dave
dhurley is offline
Old 07-03-2009, 06:53 PM   #2 (permalink)
woodnthings8's Avatar
Depending on the dealer you go to. You might have to tell them the international number for the engine T444E. Most will be able to help though.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 07-04-2009, 10:14 PM   #3 (permalink)
klhansen's Avatar
My Photos: (169)
Some International places will give you the standard line "we can't sell you parts for a Ford", but many will if you cultivate a relationship with them.
Don't put them in the position of having to refuse because your engine is in a Ford. It helps if you give them part #'s after doing some research.
There's a Ford to International part crossover here:
http://www.thedieselstop.com/faq/949...nterchange.pdf
Hard or no-start? Check Here
klhansen is offline
