Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-16-2009, 10:04 PM   #1 (permalink)
hammer101's Avatar
PCM code?
If I have my truck serviced by a dealer and he flashes the pcm will it change the pcm code and if so would it cause DP-Tuners F-6 chip not to work afterward.
Jeff P. Lexington N.C.
1999.5 F250 4x4
DP-Tuners F6
6.0 IC, 6.0 Trans Cooler
AFE Stage II , 4" Magnaflow Stainless
Banks Big-head Wastegate
CCV Mod, AIH delete
Sonnax valve/Tricumulator springs
Autometer Pyro,Trans,Boost
hammer101 is offline
Old 07-16-2009, 10:56 PM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (42)
Originally Posted by hammer101 View Post
If I have my truck serviced by a dealer and he flashes the pcm will it change the pcm code ...
Yes.
...and if so would it cause DP-Tuners F-6 chip not to work afterward.
Maybe. Call or e-mail Jody with your old and new PCM codes and he'll know if you need to download a different version of your tunes. Your tech should have noted the new PCM code on both your receipt for the work done and the truck - maybe on the air cleaner housing.
My Sierra Blanca is a '99.5 PSD CrewCab hot-rod Towing Machine! BTS tranny; Ford Severe Duty Air Induction System (AIS); 4" stainless turbo-back exhaust; DP-Tuner tunes flashed into an Edge Evolution tuner; ISSPRO EV gauges and Turbo Temp Monitor (TTM); Auxiliary Idle Controller (AIC); SP-Diesel exhaust brake and torque converter controller. Top Job front end replacement. I special-ordered it new and plan to drive it until it quits.
SmokeyWren is online now
Old 07-17-2009, 07:47 AM   #3 (permalink)
JimTJr's Avatar
My Photos: (6)
What flash would a 99 get that it already hasn't had? (And do you REALLY want it flashed? If you like it like it is, tell them not to mess with it....)
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 6pos chip, AC Stage 1 sticks, 4" Turbo back straight pipe/stainless 5" tip 131st B/W MoAirNatlGuard B-2 BOMBERS at WHITMAN AFB, Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
Old 07-17-2009, 02:12 PM   #4 (permalink)
calico5string's Avatar
My Photos: (14)
Your tuner should still work even if the PCM is reflashed.
From some conversations I have had with Jody at DP-Tuner, it is the "Family" number (the DPC-) of PCM that is more important than the actual PCM "code". The PCM "code" is sort of the version of factory-tune that is installed in the PCM. The "family" (or model number, if you will) of the PCM does not necessarily change with a different "code" (or tune). Does that make sense?
Again, your PCM's "family" number (DPC number) will be the same, only the factory tune (code number) will change with a reflash. And since the tuner's programming basically overrides the factory (PCM) programming anyway, you should be fine.
Here's a pic of the different numbers:
I used to have a list of DPC numbers and all of the "code" numbers for each, but I can't seem to find it. If I do, I will post it up.
If your chip was installed when the dealer did the re-flash, that may have damaged the chip...not good!
If the chip was not installed when they did the flash, and you re-installed it afterwards, then I would suggest you go back and double-check the edge-card connection where the chip plugs in the the PCM. Make sure the connector is clean and the chip is fully seated on the connector. That is the most common cause for a chip to stop working.
Good luck. Let us know what you find...
Al in SoCal
2000 F350 SRW CC 4X4
AFE Stage II w/PG-7
Garrett 38R Turbo
Swamps Stage II Single-shots
Stealth Dual-HPOP
ITP Custom-modified Regulated-return Fuel System
DP-Tuner PCM & F-5 chip (Live tuned!)
Autometer Gauges (Pyro, Boost, Eng oil temp)
Non-EBPV Pedestal
AIH Delete
"T444e" Open CCV
4" Custom S/S Exhaust into 5" Dual Aussie Stacks
ZF 6-Spd "Hand-shaker"
Southbend Double-Disc clutch
...plus some other goodies...
calico5string is offline
Old 07-20-2009, 01:26 PM   #5 (permalink)
My Photos: (14)
I found it!!
Here is the list of PCM "Family Codes" (Models) and "PCM Codes":
PCM Codes (Click ME!)
Al in SoCal
AFE Stage II w/PG-7
Garrett 38R Turbo
Stealth Dual-HPOP
Non-EBPV Pedestal
AIH Delete
"T444e" Open CCV
