PCM Code How to tell witch one? - Diesel Forum - TheDieselStop.com
Old 05-17-2005, 03:18 AM   #1 (permalink)
I recently bought an 02 X. The sticker on the door is gone and it was chipped why i bought it so the door on the pcm is gone as well. Can it be scan to find out the code? I also bought an edge evo for it because the chip and the "pats" were at odd's when i got it. Any help? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
02 excursion afe stage 2 with pg\7, muffler delete, aic, autometer ultra lite gauges pre and post egt,boost,trans,volts, BD edge evo, and 04 18" ford 5 spoke rims with 275/70/18"s, bilstein's front and rear with a rancho stearing stablizer
sledstorm1 is offline
Old 05-17-2005, 05:33 AM   #2 (permalink)
Re: PCM Code How to tell witch one?
Automatic....VDH
2000 psd CC SB 4x4,
This...That...And-The-Other...
OLD Powerstroke 7.3l
620.8HP/1157.9TQ Dunbar's Dyno 5/26/07
My Pics
New Cummins 5.9l 12v Conversion.
sno_cat is offline
Old 05-17-2005, 08:29 AM   #3 (permalink)
My sticker wasn't on the "door" on the PCM. Mine was on the pin-out harness at the other end-the part that goes through the firewall. He's right that it will most likely be the VDH series.
2000 F-250 SUPERCAB XLT, 4X4 OFF-ROAD, SHORT BOX, BILLET GRILLE, STAINLESS BUG SHIELD, STAINLESS ROCKER PANEL GUARDS, SIRIUS SAT. RADIO WITH P.I.E, DP-TUNER CHIP 40/70/100/125,DAHL 100, TYMAR INTAKE, H/X MOD, SP DIESEL PPM STAGE 1, 203* T-STAT & HOUSING, FUMOTO VALVE, HEATER CORE SHUTOFF, AIR INTAKE HEATER DELETE, A-PILLAR GAUGES, EBPV & WASTEGATE DISCONNECT, SONNAX/TRICUMULATOR SHIFT KIT, FUEL REGULATOR SHIMS(68 PSI), COOLANT FILTER, IN-TANK MODS, HARPOONING, WALKER BTM, WICKED WHEEL, AND NEW BOOTS. SOON-CCV MOD.
hardware45 is offline
Old 05-17-2005, 08:48 AM   #4 (permalink)
SeeYa's Avatar
2002 Excursion will most likely be a NQW?. There is 1 code of a MAP0. Or it will be a DPC-492 code. I would take a look and check it.
SeeYa is offline
Old 05-17-2005, 11:09 AM   #5 (permalink)
OOPS [img]/ubbthreads/images/graemlins/phoney.gif[/img] I missed the X part
2000 psd CC SB 4x4,
My Pics
sno_cat is offline
Old 05-17-2005, 08:52 PM   #6 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Yes. That's the only sure-fire way to determine the PCM code. The number on the door or on the PCM itself may be invalid because the PCM has been flashed with a new code.
With a good scanner/tester, you can see the current PCM part number. Then any decent translation table will convert that part number to the PCM code. We have a translation table in the '94-'97 FAQ. Click here.
SmokeyWren is offline
Old 05-18-2005, 01:03 AM   #7 (permalink)
Thank you all for the info.
