PCM "keep alive memory" error? 2000 PSD - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 07-31-2006, 03:07 PM Thread Starter
I'm geting VERY rough running and stalling on my 2000 Excursion PSD.
The code reader says " pcm keep alive memory" error...
I never had any problems with the trucks running until now...
Last week I put a CPS in it as it stalled out ( no rpm showing on tach while cranking) and at that time it show some code about the CPS sensor....
Today this new issue happened , it will start but, it idles rough and you can't rev the engine up very much at all....
I cleared the "pcm keep alive memory" code out and upon restart it just throws the same code and runs bad again.....
Do you guys have any ideas where I should be loking to fix this?
Thanks..... [img]/ubbthreads/images/graemlins/grin.gif[/img]
DynoTom is offline
post #2 of 7 (permalink) Old 07-31-2006, 03:12 PM
Banned
My Photos: (38)
Re: PCM "keep alive memory" error? 2000 PSD
That KAM code can come from a few things, but doesn't cause any running issues. If you disconnect batteries, install/uninstall a chip, it will give the KAM code.
Do you get an SES light? If so, your code reader may not be capable of pulling the P codes, what kind of scanner are you using?
gregrob is offline
post #3 of 7 (permalink) Old 07-31-2006, 03:17 PM Thread Starter
I have the Edge Evo that has the scanner on it, It really seems to have a hard time even at idle, when I give it throttle it really winds up slow, like its starving for fuel, I took the fuel filter cover off and the fuel look real clean?
DynoTom is offline
post #4 of 7 (permalink) Old 07-31-2006, 03:24 PM
Banned
My Photos: (38)
Do you get the Check Engine Light?
gregrob is offline
post #5 of 7 (permalink) Old 07-31-2006, 06:24 PM
CSIPSD's Avatar
My Photos: (52)
Sounds like the under valve cover harness has come unpluged, or is loose. The RAM code is just left over from reading and clearing the codes...
01 F-250 SC PSD,260k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Swamps Tuning and IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #6 of 7 (permalink) Old 07-31-2006, 09:20 PM
KRP
CPSs are sometimes bad right out of the box. Might put the new spare in and see what it does.
2000 F-250 Ex.Cab 4x4 Auto with Homemade Intake, 4" Exhaust, DP Tuner Chip, Tugger Kit, 2 HPOPs, ITP Fuel System/Boost Regulator, AC injectors, and Van Turbo/WW
KRP is offline
post #7 of 7 (permalink) Old 07-31-2006, 09:48 PM
I have been getting the KAM code also. But mine idels fine. It just stalls out and runs again. I checked the UVC harness and plugs and it seems fine. Changed the CPS twice and still the same problem. I got the KAM code today again and a TPS code. Going to change the TPS and see what happens. I changed the ICP sensor and will also be changing the IPR. Hope that cures the problem, I just hate throwing money around.
00 "X" Limited 7.3L PSD 4X4, 4" Turbo Back Exhaust w/BTM, Edge Juice W/Attitude, EVO, Pro Comp Ultra Lite Trans Temp Gauge, Pyro, and Boost, Pro Comp 4"Lift, 35's w/Welds 16.5X10, Exhaust Brake, Airaid Cold Intake, Clear Headlights and Turn signals, Billet Overlay Grill, Centric Slotted Rotors, Zoodad, IC Wrap Delete, CCV Mod, WW, Nathan K3LA Horns w/5gal tank, 6.0 Trans cooler,.
2003 18FT Wanderer TB
HWNSTYLX is offline
