Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 06-29-2008, 01:27 PM   #1 (permalink)
Power Loss
1999 [early] 7.3
Driving along and lose power...can barely move...Check Engine light comes on...stop, shut engine off, restart..everything is fine.
First time, I said "Oh well", but now it's happened one or two additional times.
Any ideas?
Thanks, in advance.
Ron
VTRVR is offline
Old 06-30-2008, 01:39 AM   #2 (permalink)
Mine did something similar...
Fuel pump...
It would drive fine for a couple miles... get on the highway, and it would get slower and slower.. start to buck and then stall. A couple minutes on the side of the road, it would fire up and drive just fine (after the pump cooled down)... rinse, repeat.
ChrisJohnson00TA is offline
Old 06-30-2008, 01:43 PM   #3 (permalink)
klhansen's Avatar
My Photos: (92)
Ron, your problem sounds like Under Valve Cover harnesses for the injectors, especially if the check engine light came on. They can come unlatched and the electrical connection to the injectors opens. Expansion/contraction of the plastic can make the problem come and go.
The best bet is to get a scan done, which will tell you more. If it's just a UVC coming loose, it will give you a P127X code with the X being the affected cylinder. You can also try pulling off the connector on the outside of the Valve Cover while it's running badly. If there's no change in the engine, then pull that VC. If the engine dies, then it's probably the side that you DIDN'T pull the connector loose.
ChrisJohnson00TA, Your CEL probably didn't come on when you had your problem. The fuel pump system isn't monitored by the PCM except for power to the pump.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 07-03-2008, 01:24 PM   #4 (permalink)
Thanks for the input...it's what makes this forum so valuable to me.
IPR seemed fine...didn't want to get too involved.
It did not act up again.
Went to shop and they found what they consider to be a fairly problem...the 42 pin connector has a tendancy to rub on a bracket on the left side valve cover and often wears thru' a wire. Found that on a wire for the No, 4 [I believe] cylinder and it was repaired.
Don't know it that was the problem or not...just have towait and see.
Thanks again for your responses.
VTRVR is offline
