Power Steering Flush - Diesel Forum - TheDieselStop.com
Old 09-22-2007, 05:16 PM   #1 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: klhansen</div><div class="ubbcode-body">Don't actually drain it, just flush it out by replacing it with new fluid.
What you need to do is follow the hose connected to the neck of the reservoir up to the hydroboost on the firewall. Disconnect it from the nipple there and put a piece of hose on the nipple that runs over the fender to a bucket.
Suck out all you can from the reservoir, refill with your new fluid (Mobil 1 ATF is what I used), then start the truck and have someone turn the wheels lock-to-lock and mash the brake pedal. Old fluid will come out the hose into the bucket. You also need to keep the reservoir full when doing this. If you let it run dry it will get air into the system and be noisy and the brake pedal will be jumpy till it bleeds out. Once you see nice new fluid going into the bucket, you'll be just about done. Run a little more thru for good measure, then reconnect the hose and top off the reservoir. NOW you're done.</div></div>
I am a little stuck here. I have followed the above post (I hope correctly) however after 6qt of Mobile 1 ATF I still have a cream color fluid. I am not sure what to do at this point.
2000 F250 4x4, superchip, AIS
hucklejack is offline
Old 09-22-2007, 07:38 PM   #2 (permalink)
Jinco's Avatar
Re: Power Steering Flush
I documented what I did here. Mine got nice and red after about 2.5 quarts. The cream color seems strange.
Buy Ford. They're not taking bail-out money.
2000 F250 XLT PSD Crewcab, Longbed, 4x4, Auto, LS 3.73
Ford AIS, Frantz Bypass Oil Filter, Baldwin Bypass Coolant Filter, Fumoto Drain Valve, 203* Thermostat, Stancor
Bilstein Shocks all the way around, Timbren SES (Rear), Bridgestone Dueler Revo A/T 265/75/16
Commander Monitor (gauges), Crimestopper CS-2016 DP II FM Remote Start/Alarm/Paging/Turbo Timer/Keyless
Rotella 5W40 Oil
, Texaco ELC Coolant, Mobile 1 ATF Trans and PS
My mods, repairs, and other truck Stuff
Jinco is offline
Old 09-22-2007, 08:25 PM   #3 (permalink)
The cream color might be coming from aeration. Did it get low enough for the pump to start groaning?
99.5 F350 SRW 7.3PSD 6SP CC 4x4
<span style="color: red"> autometer pro-comp pyro-n-boost, wicked wheel, Reg return, AIC mod, Exhaust brake mod </span>
banging on all 8 since 11/24/06
Tom
tlutman is offline
Old 09-22-2007, 11:10 PM   #4 (permalink)
What color was your fluid BEFORE you started changing it?
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
Old 09-22-2007, 11:56 PM   #5 (permalink)
I heard lots of whinning so i looked and found the cap was not on very good. I think I got some water in the pump. That is why I think the color is more of a cream.
Old 09-23-2007, 12:59 AM   #6 (permalink)
Banned
Air entrained in the fluid will make it "creamy" looking, too.
GrampyJim is offline
