Power steering growl. - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 04-27-2017, 03:16 PM Thread Starter
About 6 months or so, I blew one of the power steering lines, replaced it and filled it with Lucas Power Steering fluid. I has growled ever since, but now it's getting more noticeable and annoying. It even growls under brake pedal pressure.
Did I use the wrong fluid, should I flush it out.
What are the recommendations?
Thanks.
bossbotana is offline
post #2 of 6 (permalink) Old 04-27-2017, 03:55 PM
RT
RT's Avatar
Definitely used the wrong fluid. These trucks use ATF in the power steering circuit. Conventional power steering fluid will foam and lose pressure. You need to flush it and use either Mercon ATF or a synthetic like Mobil 1 ATF.
Watch this video:
RT is offline
post #3 of 6 (permalink) Old 04-28-2017, 07:50 AM
Dennis Pitzer's Avatar
The video talks about pumping the brakes while flushing the power steering fluid. Why are the brakes effected, don't they have their own reservoir? He also comments after the flush that the brakes felt much more responsive...what am I missing??
'Cinnaman'
99.5 F350SD PSD Lariat CC LWB 4R100 4X4 ESOF 3.73 4wheel anti-lock TT mirors Trailer Towing/Camper package rear slider/privacy glass/two toned paint-DarkTorreadorRed&black/A.R.E.lid-Rhinoliner-BanksTranscommand/Autometer Z Series 3 pillar gauges/SCMT80/Bullydog 4" turbo-back exhaust/full reclining seat mod/Hutch and Harpoon tank mods/ HX Mod
Born 5/6/99-I was there at the Louisville plant watched my baby being built!
Dennis Pitzer is offline
post #4 of 6 (permalink) Old 04-28-2017, 08:22 AM
The power steering pump provides fluid to the steering and the hydro boost systems.
Early '99 F250(02-98) 192,000mi,2wd,auto,Extra cab longbed,Bak Flip tonneau cover,AIS,4" turbo back exhaust,ITP regulated fuel return,SS HPX line,203 Tstat,Evans coolant,Isspro EV2 gauges on "A" pillar,John Wood HD 4R100,6.0 cooler,DP Tuner F5 chip,Terminator Scangauge
1989 F250 4x4 7.3 IDI w Banks Sidewinder turbo, 149,000 mi, Regular cab, E4OD, 8600 GVWR, 4.10 LS, Isspro EV2 gauges EGT, Trans temp, Coolant temp, Oil press, Boost press
0298PSD is offline
post #5 of 6 (permalink) Old 04-28-2017, 09:46 AM Thread Starter
Perfect, Thanks for the Video.
post #6 of 6 (permalink) Old 05-02-2017, 07:54 PM Thread Starter
That was easy, and less than 45 minutes.
Quite and smooth, just like it should be.
