7.3L Power Stroke Engine and DrivetrainDiscussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
I was getting a groaning noise when I turned the steering wheel and it was getting worse. I changed the power steering pump yesterday. The problem is a little better but there is still a noise. I'm also hearing the same noise when I push the brake pedal. My brakes aren't working as well as they were.
Is there air in my power steering lines?
Do I need to flush the power steering system completely?
Did you bleed the air at the hydroboost unit? Even if it had some air it will work it's way out.
Start the truck and turn the wheels back and forth and pump the brakes several times, then turn the truck off and
look in the PS reservoir, if the fluid looks foamy or pinkish. it's got air in it.
Let it set for 10-20 minutes and do it again. It may take several times ti get all the air out.
If it has no air in it, then try flushing the PS system and changing to Mobil 1 synthetic ATF, if that doesn't cure the problem then you may need to look at the hydroboost unit.
here is an article on troubleshooting Operation, Diagnosis and Repair of HYDRO-BOOST Power Assist Systems, Bill Williams, Brake & Front End, March 2005
Early '99 (12/98) F250 SuperDuty, 4X4, manual hubs/TCase, SuperCab, LB, 7.3L "PowerStroke" Diesel, Auto, currently running PMT3, 158K
Volant cold air intake, ITP regulated return(on hold), Edge EVO, ISSPRO under-dash gauges, BDS front leveling kit,
Michelin LTX 285/75/16, new 600watt amp/speakers/12"sub, 4" straight piped, B&W GN hitch, AE scanner on board always!
My Truck http://www.putfile.com/devdwt/images/121998
Other Toys:
2006 Z06 Corvette
1990 Jeep Rock Crawler
1999 Jeep Wrangler
2007 Harley FXSTC
"If a little bit is GOOD, a whole lot is BETTER, then too much barely is ENOUGH"
That's just the cooler, it won't kill anything if you reconnected them backwards.
Other Toys:
2006 Z06 Corvette
1999 Jeep Wrangler
2007 Harley FXSTC
When I replaced my pump had that same problem. After it sat all night it was fine the next day. I think it just had air in the system and takes a while to bleed out.
"I discovered from reading many posts on TDS that flushing the power steering fluid (ATF) and replacing it with Mobile 1 synthetic ATF might alleviate the problem."
That procedure's been here at TDS for years, but that is a good writeup.
I flushed the power steering system according to the procedure. I still have a problem. When sitting still and the brake applied I can't turn the steering wheel. My tires aren't that big. I still have noise but not as loud. Shouldn't the flushing procedure get rid of all the air? I flushed 3 quarts through it.
When flushing, does the cooler and hoses to the cooler get flushed also? By tracing out the flow paths it seem to me that this is bypassed. The return line from the cooler is routed into the bottom of the reservoir.
Where did you gat the new pump? Is it an OEM or "world class" from the generic stores?
If you've flushed it and let the air work out then I suspect the "new" pump may be faulty.
It is common for the steering to be a bit stiff while the brakes are applied because the hydoboost is robbing some of the pressure.
Pump the brakes a few time with the motor off, then push the pedal down and hold it while you start the truck. It should go down some and then stop just like a vacuum type system.
That should give you a clue as to whether the HB is causing some of the problem??
Other Toys:
2006 Z06 Corvette
1999 Jeep Wrangler
2007 Harley FXSTC
Well I lost everything today! No power steering, no power brakes! I took the pressure line off the hydro-boost and started the engine. I had fluid pressure but I don't know how much. It didn't seem like much but I did have a solid stream. I took of the pressure line at the HB that goes to the gear. I just had a small amout of fluid spitting out. I'm assuming the HB is bad. I took it off but I can't order one until Monday.
A new HB is $400!!!!!!! I wonder if I can take it apart and rebuild it?
Not rebuildable
The backup boost accumulator attached to the side is pressure charged and cannot be removed and replaced.
Check with Powerstrokeshop.com $350.00
I got one from a local dealer, the guy made me a great deal at $305.00 +tax!
Other Toys:
2006 Z06 Corvette
1999 Jeep Wrangler
2007 Harley FXSTC
I had the same noise after replacing a hose. One of the hoses got a small leak and needed replaced. I was afraid that I had hurt the pump by maybe running it dry. It did end up being air and silenced itself after a while.
Good to know about the Mobil 1 atf. I just used regular atf fluid. Come spring I think I'll drain and refill with a better fluid.
Jared
2002 Excursion Limited 7.3L PSD, Auto, 4x4, 265/75/16 Revos, Blue Gold, AFE Stage II with ProGuard7, MBRP 4" stainless, DP tuner (hi idle, stock, 40, 60, 80, 120).
1999 BMW 540i, 6 speed, sport package, totaled.
2000 BMW 540i, 6 speed, sport package, not totaled.
I took the HB apart. The accumulator doesn't need to come apart. Everything looked fine and I thought the spool valve had come loose from the linkage. There's a piece pressed in I couldn't remove. I think it may be called the dump valve. I just wanted to try it and see, I had nothing to lose. I work on hydraulic valves all the time at work and the HB isn't much different.
Anyway this was all a waste of time anyway. I should have took whitjo's advice and checked the new pump. After looking at the HB I figured nothing was wrong with it and pulled the pump. The aluminum housing was cracked half way around the groove where the ring is that holds the pump in the housing. This was allowing my pressure to escape to the reservoir when the pressure built up. I called the parts vendor and ordered another one. I hope I have better luck with this one. I would get one from ford but they're twice the price. If this one doesn't work out I guess I'll break down a spend the money. I doesn't take long to change the pump, especially when you've done it twice!!!
