Powersteering / Hydroboost problem - Brake Kickback - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 03-19-2009, 04:02 PM Thread Starter
Rogue1970's Avatar
Hey guys, I've been looking around for a few days trying to find an answer to my problem but still need help.
Alright, last weekend I was out at the Gordons Well sand drags and my Power Steering pump started to whine and it was spitting fluid out the fill cap. After it cooled down, I had no assisted steering or brakes.
Fine, got up the next day, purchased a new PS pump from Autozone along with the puller/installation tool. A few hours later and the new pump installed. When installing the new pump, I removed the hose fitting from the new pump and installed the old hose/fitting assembly so I wouldn't ruin the teflon o-ring.
Went out for a test drive and the assisted steering is working fine, but the brakes kickback and grab.
A few days later, I find the TSB for this issue
http://www.thedieselstop.com/faq/949...les/992508.pdf
Well I flushed the system by routing the hydroboost return line into a catch can and poured 3 quarts of Mercon V thru the system. No change in the brakes, they still kickback and grab.
Now after reading this TSB again, I did not rev the engine to 2200 RPM when I was doing the lock to lock or brake pedal pumping. Hmm, maybe that could help?!?
So, I guess some questions are.
  • Do I need the external filter to clean the system or is the flush method I used good enough?
  • Should I flush the system again this time increasing the RPMs to 2200?
  • Or, does it just look like my Hydroboost is out and I have to replace it?
  • If the Hydroboost is out, can I purchase just the Hydroboost portion of the module and bolt on my existing Brake Master Cylinder to it?
  • Best place to buy these parts?
Thanks for any help on this issue.
- Purchased 8/3/08
DPTuner F5, AIH, BigAir, Gauges (Pyro, Trans, Boost), ScangaugeII, Zoodad, Harpooned, Hutched, Pre-Pump Filter, Boost Fooler, Turbo Master.
Tranny out at 95K - JW Towmaster installed, Ported Compressor Housing from DieselSite - waiting to be installed
Pulling 11k Attitude Eclipse full of sand toys. 2x
s, 2x2007 Kawasaki KFX90's.
Rogue1970 is offline
post #2 of 14 (permalink) Old 03-19-2009, 08:12 PM
klhansen's Avatar
My Photos: (180)
The brake pedal will buck if you get air in the PS system. I managed to get a bit in mine when I did a flush, and it sounded and felt horrible for a few minutes. Then it was just irritating till I put a few miles on it and the air worked it's way out of the system.
You might want to do the lock-to-lock and brake thing again with the engine revved and see what happens.
), AIS,
regulated return,
klhansen is offline
post #3 of 14 (permalink) Old 03-19-2009, 08:40 PM
Donut Limo's Avatar
Thats good to hear, my pedal has had kickback ever since the fluid was low after it spilled out from manually turning the wheels while replacing the ball joints. Glad to see the bulletin, will be trying that 'cleaning cycle' next time we head out for an adventure.
EDIT- followed the procedure with the wheels off the ground and no more pedal kickback
'95 F250 supercab 4x4
'99 Accord Coupe V6 6speed swap
'90
, gone but not forgotten
Donut Limo is offline
post #4 of 14 (permalink) Old 03-22-2009, 02:30 PM Thread Starter
Rogue1970's Avatar
Well, doing the TSB recommended bleed method still didn't help. Plus, I tried the 2200 RPM lock to lock with the wheels on the ground. DON"T DO THIS. My Powersteering pump locked up and spun the pulley right off. Luckily it did not hurt anything else.
Installed the PS pump and had to find a factory pulley (drove to San Diego yesterday) to install as the old one was FUBAR.
Bleed the PS system again (wheels raised) and the kickback is still there. So, now I'm looking around for hydroboost install instructions/tips.
- Purchased 8/3/08
post #5 of 14 (permalink) Old 05-05-2009, 02:21 AM Thread Starter
Rogue1970's Avatar
Thought I should post a follow up. Well I replaced the pump again and then performed the factory recommended bleed method. This mostly worked, but a little kickback was still happening.
I decided to drive it around for a few days and the problem cleared up. The last of the air worked out of the system and it worked like new again.
- Purchased 8/3/08
post #6 of 14 (permalink) Old 07-25-2009, 03:15 PM
dieselchick08's Avatar
My Photos: (5)
Hey everyone. I am wondering where I can get this TSB you were mentioning. My 2008 F350 is in the shop right now. My hydroboost line that is common to my power steering and my brakes failed some how. My dealer is telling me it won't be covered under my warranty despite not having 36000 miles yet on it. Your description of your problem is EXACTLY what happened with our truck
dieselchick08 is offline
post #7 of 14 (permalink) Old 07-26-2009, 11:50 AM
Tell them to make the repair under your BUMPER to BUMPER warranty unless it was damaged by something you did or installed on truck they have to pay.
This sounds like they are just trying to pull the wool over your eyes.
Be assertive but polite. It will go a long way.
Mike
'04 F350SC Lariat sb cx 6.0 auto 4x4
'01 Exc. Ltd fu 7.3 4x4
'00 FLHTCUI sinister
'96 WX3 bbb
TwiceStroked is offline
post #8 of 14 (permalink) Old 07-26-2009, 07:45 PM Thread Starter
Rogue1970's Avatar
I'm not sure if the bleed method in the TSB applies to your newer truck. The link is in my first post, but here it is again.
LINK
Good Luck,
Larry
- Purchased 8/3/08
post #9 of 14 (permalink) Old 07-27-2009, 01:47 AM
My Photos: (5)
Thanks. I have now come to find out that even though at first they claimed it was a hydroboost line there is something else. Water got into my power steering system and seized up the bearing in the pump so now the pump needs to be replace and this is NOT cover under warranty. I don't understand how it could not be. I don't take my truck 4 wheeling or drive crazy with. We use it to commute everyday and to tow our camper when we go camping. The dealer is the only one who is under my hood dioing the oil changes. Do you all think I have a valid reason to fight this with ford. I am going to pay what I have to but then I am planning to contact ford about it and tell them how dissatisfied I am
post #10 of 14 (permalink) Old 08-03-2009, 12:32 PM
My Photos: (5)
Talking
well I even tried to fight with Ford about it and Ford agrees with the dealer that it is NOT covered under the Bumper to Bumper. And get this - I spent all this money to repair the damn thing - went on vacation and on our way back the same crap happened again so it is BACK at the dealer right now.
I am thinking they are going to eat their own words because they are going to discover that something else in my motor caused the water to get into my system and Ford WILL have to pay for it.
I will not let this one go - Hey thanks for all the info and I will keep you all up to date
How do I go about getting pics of my truck on here?
post #11 of 14 (permalink) Old 08-03-2009, 01:26 PM
Kanman's Avatar
With the 2nd failure I would run this through small claims court. You definitely have a leg to stand on, two even
Kanman is offline
post #12 of 14 (permalink) Old 08-03-2009, 02:11 PM
Flywheel's Avatar
Likely the newer trucks have a oil-to-water cooler for the power steering? If that is leaking, you could get cross-contamination of fluids into you PS fluid.
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #13 of 14 (permalink) Old 08-04-2009, 12:11 AM
rainy day poco's Avatar
good luck getting anything out of ford
My wife has 99 f150 we baught new. The only people under the hood has been our local dealer (lifetime oil change) and me. Last fall I was replacing headlights and noticed the factory jack handle was missing. After an hour of arguing and two different people I still had to pay for the new handle.
Black 99 Crew Cab 7.3 4X4, 01 ext cab 7.3 4x4 6" lift 38" tires , 88 chevy 3500 ext cab 20' wedge bed car hauler 85 Trans am waiting on motor , Wife has Black 99 F150 Reg Cab Stepside V6 .
rainy day poco is offline
post #14 of 14 (permalink) Old 08-04-2009, 04:50 PM
My Photos: (5)
thanks for the info - I will look into it somehow - any idea where I would find this oil to water cooler thing you are talking about
the second repair was on them as the pump failed - they are sending it back to Ford
