Prepping my oil pan for POR15 - Diesel Forum - TheDieselStop.com
Old 11-07-2009, 06:30 PM   #1 (permalink)
So I noticed a little rust on my pan, and figured I better do something about it since I love my truck, and want to keep it for a long while (or at least until we can get a rockin' diesel and a manual tranny in the SD).
Prepping the pan is a beast! I have spent a couple of hours under the truck with a sander getting the paint off on the easy parts of the pan (good reason to buy a new tool), and I just spent another hour removing the rest of the paint with paint remover. I left a 2-3" band of paint at the top of the pan since it seemed OK.
Now I need to let everything dry, sand the rest of the paint off (by hand...), and then start the POR15 prep process.
Before I do this, I have a question for those of you who have been down this road: Should I let the oil pan rust up a bit before degreasing and applying the POR15? The directions say that it holds on to rust way better than bare metal (even if you use the "metal prep"), and I sure don't want to have to do this again.
Have a great day.
2002 F250 XLT 4WD SC SB with 6 Speed and Manual Shift Transfer Case. Pillar pod-o-gauges, Warn Premium Hubs, AIS, Fumoto, Edge 3” leveling kit on the front (with adjustable pan-rod bar), 4” blocks on the rear, Eaton Posi, Bilstein 5100s and 285 X 75 X 16 BFG MTs all around. Oil pan coated with POR-15 and Silver Krylon (to reflect the mind-rays). Fleetrite ELC and Dieselsite coolant filter.
Shamish is offline
Old 11-07-2009, 09:47 PM   #2 (permalink)
dlblazer's Avatar
I've had the best luck with POR15 when I used their degreaser. If the metal has a light surface rust, the POR15 should adhere fine as well - it has on my car trailer.
The only problems I've had is where I didn't paint over the POR15 and it was exposed to the sun. The UV rays break it down.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter (no more), Superchips 1705 tuner, Reese Titan, AIS, IPT pre-pump filter kit, in-tank mods, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
dlblazer is offline
Old 11-07-2009, 10:38 PM   #3 (permalink)
DHTD's Avatar
I would wait, Ive put it on fresh metal before only to have it flake off, it works amazing on rusted parts!!
01' 7.3 4X4 DRK MTLC BLU, DP Tuner F5, AEM Intake, 4" Turboback Silverline Exhaust, BTS VB, AEM digital gauges(pyro, boost controller, trans temp), CCV mod, Rebuilt Injectors, Fuel tank Mods, 203T, 6.0 Trans Cooler, 185,000K and original tranny, so far so good.
DHTD is offline
