problems with 99 SD..stalls out only when raining or wett - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 02-13-2007, 07:16 PM Thread Starter
My truck keeps suddenly cutting off only when its wet outside or raining,runns fine all other times,anyone know what this could be ,thanks
masterblaster is offline
post #2 of 19 (permalink) Old 02-13-2007, 07:26 PM
Re: problems with 99 SD..stalls out only when raining or wett
[/ QUOTE ]Bad connection to the CPS ? Water in the PCM? just a thought....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #3 of 19 (permalink) Old 02-13-2007, 08:06 PM
Yep what ^^he^^ said. Sometimes you can unplug the CPS (hopefully not on the side of the road in the rain) and coat the connections with grease to create a better seal and cure the problem. Other times it's a windshield leak running down on the PCM.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
post #4 of 19 (permalink) Old 02-13-2007, 08:59 PM
Atlantaboy's Avatar
I guess you guys drive through 1' of water all day cause I've never seen a PCM get wet, unless he missing an inner fender completely.
I have seen the IDM get wet, and cut a truck off when raining.
2001 F250 CC 4x4 (Blown motor @ 148k)
Garmon's Diesel Performance (bang bang bang)
01' F250 CC 7.3
6.5" ProComp on 35's Motometal 951's
03' headlights/corners, billet grill, Alpine/XM
16.5:1, Mahle's .0050 with harden forged
Comp 910's, 4130 pushrods, Mac/K&N
H11 studs, HT turbo, DP tuned,
Bean's singles/plentums, DI's fuel system
Mag-Hytec cover, Autometer gauges
Built trans with Red Altos/Mojo VB/PI triple disc.
Atlantaboy is offline
post #5 of 19 (permalink) Old 02-13-2007, 09:30 PM
I have just finished towing my 99 F-350 up the driveway with old faithful 1989 F-250. My 99 cut off coming down the driveway tonight. It was raining, I did not think it was too bad, the wind was up and as I was going downhill and then uphill, it cut off. Towed it into the driveway and after sitting level it fired up. I guessed it was water related, but logged in to see if anyone else had this problem.Is this just happening to 99's?
1989 F-250 4x4 7.3 C-6 315000 miles and counting-sold
2001 Excursion Limited 4x4 7.3 165000 miles-new transmission-12-24-12
2008 F450 XLT CC 4X4 4.88 gears 11' Reading Service Body 168000 miles-too nice to be a work truck-new engine, 5th radiator
2001 F250 4X4 Lariat CC bought April 2011 185000 miles
farmtruck is offline
post #6 of 19 (permalink) Old 02-13-2007, 09:38 PM
I have a 2001 F-250 and mine would cut out when it rained real hard.So I changed the cps about a month ago and it has'nt cut out since. Is it flashing a check engine light? Whenever mine cut out it would flash the check engine light. I ran a code and it came back cps code.
2001 PSD F-250 longbed single cab, factory pipe ( muffler & cat delete), SuperChip Programer, quadzilla monitor, M.A.C. cold air intake
ghillieman05 is offline
post #7 of 19 (permalink) Old 02-13-2007, 09:52 PM
I did not notice if the check engine light flashed, I will drive it tomorrow-its my work truck- and see if it happens again. thinking about putting some dielectric grease in CPS connector just to make me happy [img]/ubbthreads/images/graemlins/grin.gif[/img]
post #8 of 19 (permalink) Old 02-13-2007, 10:23 PM
mythreesons's Avatar
I have an early 99 that started acting up only when it was raining out. I changed out the cps and it's been running great ever since.
Early 99 F250 XLT, 6 spd, Luk Clutch-Kevlar bushing, 4" MBRP Exhaust, Turbo Master Wastegate Controller, ITP Overboost Annihilator, KCM S.S. HPX Line, DiPricol Optix Gauges, DP Tuner F5 Chip with 60T,80E,100 Perf, Superchips 1805 Flashpaq (used for code reading only), Firestone Airbags, 203 degree t'stat, AIS/w fender sleeve, CCV Mod, Hutch In Tank Mod, Harpoon Mod, 6.0 Intercooler, 315/75/16 on 16X10 Eagle Wheels, Ford 08 and above rear differential cover, Royal Purple Gear lube, 2007 Grille and Headlight Mod.
mythreesons is offline
post #9 of 19 (permalink) Old 02-14-2007, 08:42 AM
GrinchF16's Avatar
My 99 350 did almost the exact same thing. I changed the CPS (very easy job btw)and it fixed it no questions asked. I am not sure exactly how the moisture effects it but it did.
1999 F-350 Crew Short Bed 4x4 - 140,000 So Far --- Check that, 173,000
GrinchF16 is offline
post #10 of 19 (permalink) Old 02-14-2007, 09:22 AM
[/ QUOTE ]You have ,I'm sure , heard of leaking windsheilds..Mine got wet that way...
Rick.....
post #11 of 19 (permalink) Old 02-14-2007, 10:50 AM Thread Starter
hmm,good info here,whats strange is,it does not have to be raining hard or raining at all,if its just wet outside it does it.also it does not do it while driving,only at idle when stoped,while driving it just sounds like a miss for a sec,then drives fine till the next stop. I assume the cps,is the cranck position sensor? where is it located in this truck,and does it need to be replaced like some have done or just the plug greased or sealed
post #12 of 19 (permalink) Old 02-14-2007, 11:41 AM
Does it do it when the wipers are on or just when it is wet out?
Early 99 Ford F-350 4X4 Extended Cab Dually, 4 in lift, 6spd, dual 5in stacks,ts 6 stage, zoodad, ccv, tymar,
240,000 miles and counting
1993 Ford F-350, 4X4, Fuel Injected 460, MUD TRUCK, 40in super swampers, Dana 60 Front, Dana 70 Rear, 10in home made lift.
1982 Mustang 302 HO
HOURS TO BUILD, SECONDS TO BREAK
mflores is offline
post #13 of 19 (permalink) Old 02-14-2007, 11:52 AM
[/ QUOTE ]The CPS is on the rt front of the motor by the bigest pully, 1 plug two wires . clean the connections & seal them with dialectric grease & see what happens.... click here ....
Rick.....
post #14 of 19 (permalink) Old 02-14-2007, 04:54 PM
Cool_Canuck's Avatar
My Photos: (12)
It is the CPS. For what ever reason, when weak, high humidity causes them to act up. You can search and you will find just about every case of these trucks shutting down in the rain is cured by replacing the CPS.
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/
; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED;
Cool_Canuck is offline
post #15 of 19 (permalink) Old 02-14-2007, 04:56 PM Thread Starter
ah camshaft sensor,I see. thanks for the pics that makes it easy.
I notice it with or without wipers running? why would that matter?
what is it doing when wet,missing a fire cycle? seems that way.
