Pros/Cons wastegate disconnect - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 24 (permalink) Old 01-11-2012, 06:46 PM Thread Starter
Joel_980's Avatar
Hey guys, my truck is a stock 99 7.3 with auto tranny, boost gauge, tranny temp gauge. I was reading online about disconnecting the red line to the WG, ******IF****** I could drive truck and watch my boost, keeping it 25ish psi, am I damaging truck or turbo?
I hear truck builds boost quicker? Also read I could expect worse fuel mileage. What are the truths and pro and cons? I love working on my truck, free tweaks, or cheap mods. I'm cheap. Period.
Sent from my Autoguide iPhone app
99 f250 7.3L, crew cab, long box, 4x4
Joel_980 is offline
post #2 of 24 (permalink) Old 01-11-2012, 10:14 PM
Waste gate's purpose is that if you build up too much pressure it opens up the valve and dumps the excess preventing you from doing any damage which is why to bypass without a boost gauge or to not watch a boost gauge means this can be a very bad idea. You also need to know that there is a fine line with high performance and fuel mileage and engine wear.
Going hi-pro with semi's, we'd take them straight out the back door BUT fuel mileage was dependent on how they got driven and making them that responsive also meant nobody else was ever allowed to drive the trucks under any circumstances because all safety was removed. My son takes my truck sometimes do I really want him to be able to take it out the back door knowing he won't be paying as close attention to those gauges? I want to take my truck to the point of pure enjoyment to drive and to gain fuel mileage but not to the point that nobody else can drive it and not to the extent that the additional horsepower will take from the life of the engine.
Other question, what have you done to your truck so far? Rule #1 on any engine, gas or diesel, never mess with fuel or turbo until you've addressed intake and exhaust. To do otherwise is like forcing someone with emphysema to run a race.
CATperformance is offline
post #3 of 24 (permalink) Old 01-11-2012, 10:58 PM
If you don't have any mods, disconnecting the wastegate actuator won't make any noticeable difference on a Powerstroke.
As CATperformance said, the wastegate is to prevent overboosting. It does not control how quick the turbo spools up. The stock fuel programming on a 7.3 isn't enough to cause a stock turbo to build any more than it's intended boost anyway.
Evel486 is offline
post #4 of 24 (permalink) Old 01-12-2012, 05:46 PM
The stock Ford waste gate actuator starts to open at 5 PSI. That is low and just a waste of boost. Disabling the stock waste gate won't make a noticable seat of the pants difference, it won't build boost any quicker, it also won't make your fuel milage go down unless your right foot helps out and you won't overboost like out of control. Why would you want to keep your boost 25ish? Towing or hot rodding? Stock you really have to be towing hard or running hard to get it there. Doesn't it pull a code and defuel? Anytime you ask youself am I hurting something you probably know the answer, if you aren't hurting something already you are risking something. That OK I just like to have a good reason when I do it
2002 F250 7.3L PSD, bought new now at 202K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
post #5 of 24 (permalink) Old 01-13-2012, 08:26 PM
From everything I'm reading and my own experience it's purpose is best suited to cold weather. Someone attempting to say the only purpose of a waste gate is to build up heat in the cab of a truck really doesn't know jack about how things work and why. I honestly don't know allot about these trucks which is why I am here BUT I do know the electronics do know what they are doing, do perform the way they are suppose to, it's hard to fool them into doing things and that forces you straight back to basics of how an engine runs efficiently. Electronics compensate for allot of idiots lack of knowledge of synergy. You can run over large straight pipes too but doing that past the elbow only impresses clueless idiots.
post #6 of 24 (permalink) Old 01-13-2012, 08:59 PM
CAT- I think you are confusing the wastegate with the EBP valve. EBPV creates back pressure to aid warm up, wastegate limits turbo boost.
Oneof6- the stock wastegate does open at 5 psi pressure from the wastegate solenoid- it does NOT open at 5 psi boost. The PCM determines at what manifold pressure the solenoid is activated.
Evel486 is offline
post #7 of 24 (permalink) Old 01-14-2012, 06:24 AM
Ok, I was told the opposite here on the forum several years ago. However, there has to be a parallel between boost produced and wastegate opening. Do you know what that stock set point is? Anyway I have tried disconnecting mine and it makes no noticible difference in normal driving. So for the OP, the way you are rigged stock there it no reason to do it IMO.
Oneof6 is offline
post #8 of 24 (permalink) Old 01-15-2012, 07:44 AM Thread Starter
Joel_980's Avatar
I also have heard wastegate starts opening at 5psi. Does it open mechanically from 5 psi boost? Cause if it starts dumping boost so early there must b some way to make small adjustment, maybe install stiffer wastegate spring? I had a Garrett 60 trim on my car, and I put stiffer spring in. Not sure if this would all make sense
Joel_980 is offline
post #9 of 24 (permalink) Old 01-15-2012, 10:14 AM
69mach1377's Avatar
The red line is mechanical input to the wastegate, regardless of what the electronics want or expect, correct?
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, Bigger 66/88mm Billet Compressor wheel with ported shroud, BPV delete.
Jayco 26BHS elite, no RV parks...just the woods.
69mach1377 is offline
post #10 of 24 (permalink) Old 01-15-2012, 11:47 PM
The PCM starts to open the wastegate at about 20 psi. The way it operates the actuator is via the pressure switch with the red plastic line. It takes 5 psi pressure to move the actuator rod. This is control pressure, not boost pressure.
Evel486 is offline
post #11 of 24 (permalink) Old 01-16-2012, 12:37 AM
It starts to open the waste gate early in the boost cycle until it fully opens at 20 psi. It's a linear actuation, not a solenoid. You lose a small bit of boost as it opens the gate. You will notice a couple psi higher boost when the red line is disconnected plus it builds faster.
audiocontr is offline
post #12 of 24 (permalink) Old 01-17-2012, 12:51 AM
The actuator is a linear rod, it is controlled by air pressure through a solenoid controlled by the PCM. (Just follow the red line back from the actuator) It STARTS to open at about 20 psi boost. Disconnecting the red line from the wastegate actuator may give you a little more boost, but it will NOT build boost quicker.
Texkenusmc likes this.
Evel486 is offline
post #13 of 24 (permalink) Old 01-18-2012, 01:11 PM
69mach1377's Avatar
So it sounds like the red line pressure is like a relief valve to supplement the PCM command just in case it's not enough, like a spike in boost pressure?
post #14 of 24 (permalink) Old 01-18-2012, 01:30 PM
klhansen's Avatar
My Photos: (180)
The red line to the actuator is an assist in opening. It works agains the spring in the actuator. The PCM command either connects the actuator to the boost tap to the intake (atmospheric pressure). In the latter position, only the spring in the actuator has any affect on the wastgate, making it harder for the exhaust pressure to push it open when exhaust pressure (not boost) builds. When boost pressure is connected to the actuator, increased boost opens the wastegate, thus bypassing exhaust (drive) pressure around the turbine wheel and reducing the speed of the turbo and capacity to build boost on the compressor side.
There's a program in the PCM that decides under what conditions the boost port is connected to the actuator. I'm guessing, but it probably looks at Accelerator Pedal Position, Boost (MAP), and a few other things.
), AIS,
regulated return,
klhansen is offline
post #15 of 24 (permalink) Old 01-18-2012, 07:33 PM
I ran mine unhooked for years. The only time the boost alarm went off on my monitor was when I was pulling a camper uphill and hard on the throttle. In normal driving circumstances even flooring the truck I would have to change gears before I ever made 25psi.
2002 F350 CC PS DRW 4X4, AFE Stage 2 Intake, Rosewood Stage 1 injectors, DP Tune, 4" turbo back exhaust, X wheel compressor.
creteus is offline
