PSD burps and dies in So California/Need Mechanic - Diesel Forum - TheDieselStop.com
Old 05-16-2005, 05:41 PM   #1 (permalink)
Hi Diesel Folks,
I have a 2001 F-350 PSD with 50k miles. It just burped and died yesterday, then started and was OK. Today, it did it on the freeway; lost power, then restarted, a couple of times. I am in the middle of a tank of fuel from the usual place. I drive this beast around with a little kid, and can't be sitting on the freeway, maybe to start up again, maybe not.
I read about the Camshaft Sensor thing... sounds likely? So, now I am looking for any recommendations for a diesel garage in the San Gabriel/Pomona valley area of southern California. The local Ford dealer knows slightly less than I do about diesels- and charge through the nose for their ignorance.
Also, someone changed the chip in this truck before I bought it so now, the diagnostics don't work- it says 'check engine light' all the time. Dealer can replace computer for $1200 to tell me they don't know what's the matter- no thanks.
It would be dandy to find a reliable and experienced diesel mechanic in my area to work on this stuff- first issues I've had owning the truck for two years, 30K miles.
Thanks all!
Suzanne
Suzanne is offline
Old 05-16-2005, 06:57 PM   #2 (permalink)
My Photos: (10)
Re: PSD burps and dies in So California/Need Mechanic
The best truck shop that Ive found in southern cal is in fontana, It is a Ford truck shop not a car dealer. Just off cherry going east go across 10 and go north one block and turn left into the truck shop.
j_apetersen is offline
Old 05-16-2005, 08:34 PM   #3 (permalink)
Ran440's Avatar
Suzanne
Welcome to The Diesel Stop.
If I were you I would run from that dealer. Your puter is probably fine. Just needs to have the chip removed so they can scan it.
BTW I paid about $300.00 and some change for a new puter.
About your original problem, it does sound like the cam sensor. This is an easy fix. Prices range from about $80.00 to almost $200.00 depending where you go. Some of the sponsors on this site have some great prices. Anybody who is a little mechanically inclined can change the sensor.
Always nice to have a lady visit the site
Good luck,
Randy
1999 ( Build date 10/98 ) 1-Owner F-250 XLT PSD, XLE8 ( started out as XLE4 ), Auto Trans w/sonnax valve tricumulator springs, 4x4, manual hubs, manual shift transfer, 3.73 gears, Tymar intake, open air CCV, A-pillar 3 gauge W/Auto Meter pyro, boost, trans and axle temp in Mag-Hytec covers, Banks 4" monster exhaust, DI 4 Position Flip Chip stock-75-100-110, early 99 turbo conversion W/ ATS BB Turbo, gutted EBPV, Smitybuilt bumper guard, Lund bug deflector, Lund SS cold air grill guard, Wet Okole seat covers w/Powerstroke logo, custom made floor mats ( way better than any store bought mats )
http://community.webshots.com/user/ran440
Buy American, Keep Your Job.
Ran440 is offline
Old 05-16-2005, 09:46 PM   #4 (permalink)
JimTJr's Avatar
My Photos: (20)
Suzanne.. Welcome to TDS! If you crank the truck after it dies...and doesnt start. Does your tachometer move a couple hundred RPM? If the tach is dead then I would change the CPS. And I am glad you know to stay away from that stealer that wanted 1200 to change the puter...sheesh. That is a 15min job. And the puter is not over maybe 500 thru them. (As mentioned above,,you can find them for 300 or so.)
Let us know what you find..ok?
It takes a 10mm socket, short extention and ratchet. 1/4" is ok, and is a whole 15 min job for the first timer MAYBE. Maybe faster....lol
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
Old 05-17-2005, 07:54 AM   #5 (permalink)
Welcome,
First of all pull the chip out and see if the SES light goes off, if it doesn't then get ahold of the SOCAL association (anyone have a link?) and they will get you hooked up and can help you out!
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 05-19-2005, 02:55 PM   #6 (permalink)
Suzanne, I live in the Glendale area. If ya need any help, I'll be glad to offer a helping hand! My brother and I work on our own rigs. We've done all the modifications to our rigs. The only thing we had our dealer do was the waterpump and turbo pedestal- because it was only a $100 deductible each time [img]/ubbthreads/images/graemlins/biggrin.gif[/img] I've had great results with Galpin Ford in the San Fernando Valley. For a dealer, I believe they have the best diesel mechs in So. CA. Keep us updated!
P.S. Our 7.3s come with a standard 100k mile warranty. It should only be a $100 deductible, if you only have 50k miles.
'01 PSD 7.3L Excursion Limited EBM1, MPT81s, ORU dual shock hoops, King piggybacks all around, Magnaflow T304 system w/5" tip, FTVB w/50/50 mix regular Mercon/Mobil 1 in trans, Mobil 1 PS flush, Tri-pillar loaded w/Di PriCols (EGT,trans, boost), TS 4 pos. switch chip, ConFerr Rack, Cobra CB, TT/sig mirror conversion, 170 hi-amp alt, Hi Lift equipped, UltraDuty rearend cover w/Mobil 1 syn. w/OE friction modifier, Hutch/ITP intank mod, 2 Micron Dahl PrePump, FPR Jack shim mod@ 70psi, 203 deg T-stat & billet housing, Hawk pads, Centric rotors, Valvoline synthetic brake fluid 105.5k so far...
Recent mod: Dieselsite Coolant filter 4/21/05 @ 1100 @72 degs. F ambient temp ;P
Dec 2010 ALMOST BACK ON THE ROAD!
Vindicator is offline
