Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > 7.3L Power Stroke Engine and Drivetrain
7.3L Power Stroke Engine and Drivetrain Discussion of the 7.3L Power Stroke diesel engine and drivetrain in the 1999-Up Super Duty trucks and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 02-02-2007, 11:41 PM   #1 (permalink)
Pulled codes. EBPV? Should I fix or remove it?
I pulled P0470 - exhaust back pressure sensor ciruit error
and P0478 - exhaust pressure Ctrl valve high input.
Has my EBPV gone bad?
Is there a cheap fix like a sensor to replace?
If not, I'm thinking of removing it, and found some replacement parts rather than just gutting it.
Garrett Non-EBPV Cover Plate Mfg Part # GA-4512740005 and
Garrett Non-EBPV Pedestal Mfg Part # GA-7026700002 from http://www.longislandperformancediesel.com/
Will I need both the cover plate and the pedestal to correctly eliminate it? Will this fix my problem and cure the codes? I also thought about a banks power elbow, but I already have a 4" turbo back downpipe and exhaust and I'm not sure if it will be conpatible?
Any help or suggestions would be appreciated.
Thanks,
-Carl
The_Mule is offline
Old 02-03-2007, 02:21 AM   #2 (permalink)
Re: Pulled codes. EBPV? Should I fix or remove it?
OK, I found a EBP sensor eliminator @ http://www.dfuser.com/mfg/powerstrok...rs/Sensors.php
I assume this will cure the codes if my sensor is clogged/bad. But will I have any problems with the EBP valve sticking closed?
How can I tell if the valve is sticking closed, besides high EGT's since I don't have guages yet.
-Carl
The_Mule is offline
Old 02-03-2007, 10:18 AM   #3 (permalink)
The EBP eliminator keeps the PCM from throwing the code you got.It will not fix the EBPV itself if it is sticky.You will know if the EBPV is closed not only from high EGT's ,but also NO power .I would replace with a non-EBPV pedestal.
'02 Black F-350srw Lariat. 7.3/CC/SB/OR. TN .84 w/Hi-flow outlet,Non-EBP ped,BWD coated/bellowed up-pipes,D.P.F5(stock,Hi-idle,60tow,80econo,120race),4" SS Magnaflow,BDS stabilizers ,Fluidampr,AFE Stage2w/PG7&pre-filter,Spearco 6.0 IC,Sonnax,FT T/C,PML pan,6.0 cooler,HPOX,Airdog,ITP reg.return,MAP Maximizer,8 spring front, BFG 315/75/16 AT's,DTS 4.56LS gears,untrue Truspeed,Mag-Hytec cover,Dieselsite SS ESOF lines,coolant filter,203* stat w/billet&Fleetrite,Optix fuel on column,Ultra-Lite trans,pyro,boost on pillar.All fluids Mobil1,Energy polys,Centramatic,Fumoto,Billet,Line-X,Husky box,Extang,EGR,Alpine,Viper,Dynamat,Sirius,PIAA,Hu sky-Liner,Bilsteins. Door ding,overhead console,Snowman,Zoodad,Harpoon,AIH,Marinco,CCV,foi l mods.
ELLIOT02 is offline
Old 02-03-2007, 10:58 AM   #4 (permalink)
jgarden's Avatar
See my post. These eliminators seem to leave some codes in the computer. They may not be able to be seen with std code readers, but with AE I seem to be able to see it. I am still trying to figure out if I got a bad sensor eliminator, etc?
TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Jack
jgarden is offline
Old 02-03-2007, 11:50 PM   #5 (permalink)
^^^ interesting.
Today i cleaned the AIT sensor and pulled the EBP sensor tube to clean it and found that it has a hole in it!
Has anyone else had this happen? I assume this is causing an exhaust leak since it's coming from my exhaust manifold. Can I patch it, or do I need to get a replacement?
The_Mule is offline
Old 02-04-2007, 03:00 AM   #6 (permalink)
NorCalDiesel's Avatar
I am seeing the same codes and was getting ready to drop an email to support at dfuser.com. Have you heard from them? I noticed you have the stage 2 EBP sensor eliminator and the EBPV terminator. I only have the terminator. Maybe I need to either clean the EBP tube or get the eliminator.
2002 X PSD, Billy Boat 4", AirRaid, Gillett Diesel Service Turbo, High Output turbo exhaust housing, KCM HPX Crossover, ITP Overboost Annihilator, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp
DP-Tuner 6 pos No Start - 140 Aggressive
Thanks Jody and Diane
NorCalDiesel is offline
Old 02-04-2007, 06:27 AM   #7 (permalink)
Just a quick FYI: I had that first code and the hole too. I replaced the tube and sensor and it fixed it. The old tube was completely clogged shut.
LUV MY TRUCK! 2001 F350 7.3L PSD 4x4 White SC Dually, 158K mi (bought 5/04), Lund Scoops, Transgo Tugger, Mag-Hytec Pan, V10 cooler, 4 Rockford Fosgate spkrs, Pioneer CD, ((((XM)))), CRLaurence Powr-Slider, SUV Headlight Harness (x2), Sylvania Silver Stars, Suncoast Trans / Triple-Disc Converter, Centramatic balancers front and back.
Planned: downpipe, Exhaust, Aero Turbine 4040L Muffler/Res, Guagepod, Chip, Performance Brakes, Stainless Lines, Engine Brake, Small lift, Visor, TruckLite, Mag-Hytec Rear Cover, replace Steps, Rear Flaps, aFe Intake
Mods and Fixes: EBPS, MAP Sensor, Trans range sensor and harness, Gas pedal mod, Shocks, Front wheel hubs at 155K, Ball joints and U-joints at 158K, waterpump at 163K
Planned Mods: HX, Harpoon, Zoodad, CCV and more!
HaulinDuals is offline
Old 02-04-2007, 10:02 AM   #8 (permalink)
jgarden's Avatar
NorCalDiesel, obviously the terminator will not make up for any codes associated wtih the EBP sensor. However, I have both the eliminator and terminator and am still seeing codes using AE. What code are you seeing? Onces associated with the valve or sensor?
I have been communicating with dfuser. I need to check the resistance of the terminator I have and send in the numbers to see if it is problematic. I will post back after I do that.
Jack
jgarden is offline
