well yesterday i noticed a knocking noise with no consistent conditions, so i started poking around, right rear tire side, when i hit bumps or certain turns it will make a knocking noice, so anyway
i can go and push on the truck above the tire, when i rock it side to side hard enough i hear the same sound coming from the end area of the axle just a popping noise or a knocking noise, ive inspected all other componets around that are close, no things are lose or broken, bolts are tight, no leaks from the end of the axle of fluid, and cant see any damage, the rear is 3.73 limited slip with about 138k on it new diff fluid bout 2k ago with ls addit. my haynes manual isnt to helpful for what im looking at i guess. any help guys, where do i start at? thanks again
