why would my rear end chatter or stutter when turning a corner left or right. when I go straight nothing happens, and yes I have the additive
in the rear end and it still does it. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
You may need more friction modifier. I put Amsoil in mine and it was said not to need it. After about 10K miles the shudder appeared going left or right. Needed to add friction modifier.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
Not to be a hole in the bucket, but the same thing happened to my parent's '03 F-250, and it turned out the clutch pack in the rear was destroyed. They only had just over 50K miles on it when it happened. Same symptoms..... just fine in a straight line, but shudders when cornering. Sad thing is the symptoms have popped back up again recently.
really well I hope I do not have to do that how much will it cost to have that fixed.
I have put the whole tube of friction modifier plus i use amsoil in the rear end.
how much would one of those would cost i just called ted russell ford
and they told me it would cost 1200 to 1300 dollars to fix it.
do you have a web site that i could look at.
How many ounces were in the tube of friction modifier? I had to use a little more than one bottle in mine when I switched to Amsoil. I think I ended up with 6 ounces.
Dennis
'99.5 F250 4x4 SC 6 speed 3.73 LS, Magnaflow 4" exhaust, South Bend con-o clutch.
I am currently going through the same problem. My advice at this point is have fresh fluid and 8 ounces of modifier, as recommended by ford. Then do some figure 8 turns and give it some miles and see if it stops. If not, then you are in my boat- scheduling a new LSD install. I have chosen the detroit truetrac and will hopefully have it installed next week. I chose the truetrac because it is gear driven and no clutches to wear out again.
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 96,100 miles. truck Pictures
1200-1300 is a rip call your local gear diff shop and see what he can do for you i bet you could get a new Eaton at your local shop installed for 700 or less. I will look around and see what I can find on the net and post back.
2002 FORD F-250 CREW CAB 4X4 7.3 LITER POWERSTROKE DIESEL
DP TUNER F5 W/ STOCK,HI-IDLE,60 TOW,80 ECONO,100HP,140HP,SMOKE,
DiPricol OPTIX GAUGES BOOST,EGT,FULL SWEEP TRANS TEMP,
AFE STAGE 2 INTAKE,4" MBRP TURBO BACK EXHAUST WITH A 5" TIP,
DETROIT LOCKER,MAG-HYTEC DIFF COVER,LIMO TINT ON ALL WINDOWS,
2 VIAIR 480 COMPRESSORS,8 GALLON AIR TANK,NATHAN P3 TRAIN HORN
Andy
The lowest price that I could get for the truetrac with bearings and shims was $595. I am purchasing mine through the gear shop that I am having the work done, they are charging basically the same. The average install price that I have run into in my area is $425. The eaton posi is basically the same cost.
The place that I chose is supposed to be very reputable, but is 3 hours from home. THe install price is much cheaper than in my area though.
