Recalled CPS Lose fuel mileage? - Page 2 - Diesel Forum - TheDieselStop.com
Old 07-16-2009, 12:48 PM   #16 (permalink)
txfxl's Avatar
its up front, right under one of the pulley's, maybe the crank pulley, don't recall. you can get at it from below with a 10 mm socket and a 1/4" ratchet and extension
2000 F250 ext cab 8' Bed, 4x4, AFE Stage II, Warn Premium Locking Hubs, MBRP 4" Turbo Back, 3 Gauge Pillar (Turbo, Pyro, Trans), Racor CCV Filter, AIH Delete With Code Fooler, Wicked Wheel, Oil Crossover Line, Coolant Filter, 203* Thermostat, Stancor GPR, Under Hood Fuel Pressure Gauge, DB Starter, ITP In-Tank Mod, Intenational Bellowed Up-Pipes, Peripheral Ipod Direct Connect
Chip and a valve body in the overtime funded near future
txfxl is offline
Old 07-16-2009, 02:16 PM   #17 (permalink)
thanks for the reply. i think ill get a spare.
tinkerr is offline
Old 07-18-2009, 12:56 PM   #18 (permalink)
Mine is running fine with the gray CPS. I haven't noticed a decrease in fuel economy, but it did fail the #3 and #8 contribution tests (dealership tried to sell me new injectors because of this).
Dennis
'99.5 F250 4x4 SC 6 speed 3.73 LS, Magnaflow 4" exhaust, South Bend con-o clutch.
The_Dude is offline
Old 07-18-2009, 03:16 PM   #19 (permalink)
I'm switching mine out this week and see what the new scan will show.
Stock 2000 Ford F-350 Lariat, 4x4, 7.3 Powerstroke, Automatic, Crew Cab, Shortbed. 160k miles on it. (NOT a dually) No chips, or additional guages.
Countrygirl43 is offline
Old 07-19-2009, 11:12 AM   #20 (permalink)
GRANPA's Avatar
Has there been a new recall on these?
GRANPA is offline
Old 07-19-2009, 11:14 AM   #21 (permalink)
GRANPA's Avatar
Has there been a new recall on the CPS?
GRANPA is offline
Old 07-19-2009, 11:32 AM   #22 (permalink)
Bill1013's Avatar
NO not yet.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
Old 07-19-2009, 12:23 PM   #23 (permalink)
Bill1013's Avatar
Be carefull when you go to an IH dealer for a CPS, They have 3 different Part Numbers for those. You have to have the engine serial number for the correct one. Serial number is stamped next to the oil filter, difficult to see and read.
Bill1013 is offline
Old 07-20-2009, 12:32 PM   #24 (permalink)
Parts man at IH dealer told me serial #375548 and lower uses the black cps. He referred to it as #99. 375549 and up use the new design. He has 2 blacks in stock($41), heading his way.
tinkerr is offline
