Removing Upper Steering Column Shroud 99 F-250 - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 01-15-2006, 10:05 PM Thread Starter
My OD light also works intermittently because of a broken wire off shift lever. I cant get the upper shroud off because the ignition or key cylinder holds it from being removed. Any suggestions? Thanks.
wgvernon is offline
post #2 of 6 (permalink) Old 01-15-2006, 10:08 PM
Re: Removing Upper Steering Column Shroud 99 F-250
I'm pretty sure you just have to pull the shroud out over the key assembly to get the shroud off. I did mine 5 years ago, so I don't 100% remember if that's what I did or whether I pulled the key switch assembly out before I removed the shroud.
2013 250 Lariat CCLB, 6.7, 4WD, all but the roof, Amp Research Power Steps, BedRug, ARE cap, power tailgate lock.
2000 250SC,4WD,4R100,3.73 rear,loaded, Leer XL160
fxdwg is offline
post #3 of 6 (permalink) Old 01-15-2006, 10:23 PM Thread Starter
The switch is significantly larger on the outside than the hole in the shroud on mine. I can't figure out how to remove the key switch assy.
wgvernon is offline
post #4 of 6 (permalink) Old 01-15-2006, 10:29 PM
cgroveusa's Avatar
CLICK HERE for pic of key switch removal pin/hole
The lower hole is where you need to insert a straightened paper clip to release the lock cylinder.
Joe
02' F-350 XLT SRW 4x4 RC L/B PSD - BTS Trans - 6.0 trans cooler - Magnaflow 3.5dp to 4" back - AIS w/fender mod - AIC - Turbo-Saver - Stancor GPR - Bilsteins - Autometer Z-series - LL#8 delete - In-tank mod/pooned/pre-pump delete - Dahl 100H - Coolant filter - Helwig Rear Sway - Reese 15k Pro - Prodigy Br Ctrl - Marinco Plug-In - Rhino Liner - Cobra 18WXSTII - Towing 04' 38' CITATION f/w 375SBS 19,600# GCW
06' Mustang GT conv
SUPPORT OUR TROOPS...THANK A VET!!!
Assist Our Wounded Military:
cgroveusa is offline
post #5 of 6 (permalink) Old 01-15-2006, 10:30 PM
fordmastertech's Avatar
Turn the key to the run position. If the lower cover is still in place there is a hole side of one of the mounting screws under the lock cylinder. Take a small screw driver or ice pick and push it up into the hole. There is a button on the lock cylinder that must be pushed to release the cylinder. Once the button is pushed just pull the cylinder out. If the bottom cover is off you should be able to see the button under the ignition lock cylinder.
FMT
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
post #6 of 6 (permalink) Old 01-15-2006, 11:40 PM Thread Starter
Thanks guys. I saw the button but didn't realize the key had to be in the run position for it to work. I'll get to it tomorrow morning.
wgvernon is offline
