Replacement 7.3 serpentine belt- Correct part # - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 01-28-2011, 05:30 PM Thread Starter
sasha_j's Avatar
Hey All,
I want to replace my serpentine belt. (Called out as a "Drive Belt" on Ford Parts.Com) Apparently, there are 2 different Motorcraft part #'s for my truck's configuration. I have the build sheet for my VIN and it shows no "cold weather package". I do have California Emissions Package and a Block Heater. (Maybe the block heater is the cold weather package??)
These are the 2 choices:
Motorcraft # JK8-1227
7.3L; Single alternator; Without cold weather package.
Motorcraft # JK8-1223-AA
7.3L; Single alternator; With cold weather package.
I was wondering if someone has the same truck I do and knows the correct Motorcraft part #, thanks.
As I side note, I hate how Ford Parts.Com has you enter your VIN to make sure you get the right part, but then the search results still show you parts for every different engine and option. You would think that the search results would be directly tied to the VIN!!!
If anyone has a better source for accurate parts, I'm all ears too.
Regards,
Sasha J
1999 F450 7.3 PSD CC 4x2, Roll-A-Long Hauler Bed, 15,000 GVWR, 26,000 GCVWR, PacBrake PBRX exhaust brake, HP625 frame mount compressor, 5 gallon air tank, AIRSAFE 25K Air hitch & KSH 80 Gal Aux Tank/Tool Box, aft OEM 25 Gal Fuel Tank
2006 FR Sandpiper Sport F37 Toyhauler, 16K GVWR, 7K axles, 17.5" Wheels, 600W Solar
SOLD: 2005 F350 SuperDuty 6.0 PSD Auto Crew Cab Long Bed 4x4 SRW Lariat
sasha_j is offline
post #2 of 9 (permalink) Old 01-28-2011, 05:58 PM
woodnthings8's Avatar
You need the Motorcraft # JK8-1223-AA.
It is 122.3" long and is the most common belt on our trucks.
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #3 of 9 (permalink) Old 01-28-2011, 09:14 PM
Cold Weather Package
Here is a link to a description of the cold weather package. Maybe this will help you to figure out whether or not you have it.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: starter, batteries, cps, brakes, tires, alternator, ball joints, AC compressor, serpentine belt.
DonWarkentin is offline
post #4 of 9 (permalink) Old 01-29-2011, 04:20 PM
jgarden's Avatar
Why does the cold weather package impact belt size?
Are there PSDs that came without the cold weather package? Isnt the block heater standard, as well as the EBPV? (maybe some PSDs made for other countries??)
TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Jack
jgarden is offline
post #5 of 9 (permalink) Old 01-29-2011, 07:40 PM Thread Starter
sasha_j's Avatar
Excellent question that I too would love to see explained..
Regards,
Sasha J
sasha_j is offline
post #6 of 9 (permalink) Old 01-30-2011, 11:27 AM
Per my knowledge the only difference regarding Serpentine Belt size is whether you have one or two alternators. I replaced my Serpentine Belt with a new Napa P/N: NBH25081223HD (Gates Micro-V VK081223HD Green Stripe FleetRunner) heavy duty 8 rib Serpentine Belt. At the same time I replaced the Top Radiator Hose with a new NAPA P/N 066 Rerouted Curved Hose ( 6A31 EBP 80MH70 ZDS 0143) (For 2 Alternators Kit) that allows the Serpentine Belt to be changed without removing the Top Hose. I saved my original Motorcraft Serpentine Belt which was in good serviceable condition and be kept it as a spare.
Jim
2000 F250 SD Lariat, SC, SB, 4x4, 7.3L PSD, 6-Spd ZF Transmission, 8,800 GVWR, 20,000 GCVW, Reese Class-V Tow Beast Receiver Hitch, Prodigy V2.6, 4" MBRP Stainless Steel Exhaust, AIS Induction Air Filter, AutoEnginuity
jlrsn is offline
post #7 of 9 (permalink) Old 01-30-2011, 01:29 PM
The dual alternator belt 138 1/8" long.
I have not seen any information on why the "Cold Weather Package" changes the belt, but I imagine it has something to do with the alternator pulley size. I do know that if you put the longer 122.7" belt on in lieu of the 122.3" belt it will work, but you will get strange sounds from the belt as is is not tensioned properly. It will vibrate at idle from the alternator down to the PS pump.
Ken
post #8 of 9 (permalink) Old 01-30-2011, 02:48 PM
EXODUS's Avatar
Thanks Ken... just had an "ah-ha!" moment. I have that odd vibration from the alt to the ps pump. Wrong flip'n belt. Nice.
God bless
Robert
1999 F-350 7.3 Super Duty Dually
5" Exhaust, Edge Juice Controller
Tymar Intake
Bilsteins
350K (so far)
EXODUS is offline
post #9 of 9 (permalink) Old 01-30-2011, 07:25 PM
Yeah ask me how I know that they vibrate! Not very happy when I figured out they gave me the wrong part. Now I just order everything through Tousley Ford Parts.
Ken
