replacing block heater - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 11-05-2005, 02:16 PM Thread Starter
My Photos: (12)
After my truck was plugged in for a few hours yesterday (it was 10 outside) I reached under and felt around the block heater and it was cold ???? I havent checked the wiring to see if I am getting power to the plug yet, but if there is how hard is it to replace the block heater ???? do I have to drain the oil ???? I really don't want to anything, I's to bloody cold out and my truck wont fit inside.
[img]/ubbthreads/images/graemlins/blush.gif[/img]
Proud Member of the NRA
Newest toy Arctic Cat 400 TBX
2000, PSD F350, CC, Offroad, 3.73's, auto.
<span style="color: red"> 8 inch lift, 35 inch Cooper Discoverer S/T NAPA open Air element,
Edge Evolution, AIC in Dash, CCV MOD, BD`s X Monitor gauges,
Oilguard Bypass Oil System, AIH Delete </span>
xdodge is offline
post #2 of 9 (permalink) Old 11-05-2005, 03:05 PM
Re: replacing block heater
I would first check resistance in the cord and element first. I have seen many cords go bad before the elements do.
If the element is bad, remove the cord and loosen the element. Attach a wet/dry shop vac to the rad. cap and turn it on. The vacuum will keep the coolant in the system as you remove and replace the heater element. You will probably lose less than a cup of antifreeze using this method.
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
post #3 of 9 (permalink) Old 11-05-2005, 05:16 PM
Check the cord. Mine went bad right near the plug. Cut wire and replaced with new plug (Home Depot). Good as new! [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img]
1999.5 F350 K&N filter, Wicked Wheel,18K Mod,4" downpipe,aeroturbine, afe proguard 7, Auto meter pillar gauges(pyro,boost,Tranny temp)sonnax valve, 4 wheel drive 7.3 powerstroke, 1997 F450 Dump 460 gas, 1997 Expedtion 5.4, 1989 Corvette, kubota L2650 tractor with backhoe and loader, 1991 Cr 250R Honda, 1998 Kawasaki Bayou, love my pickup the most!!
Gearchangr is offline
post #4 of 9 (permalink) Old 11-05-2005, 07:05 PM
I agree with everyone else, I have seen more cords go bad than heaters. I have had to replace 2 myself over the years. Although I did have to replace the heater on my 94 and I wish I had known about the shop vac trick then. Even after draining, I still took a bath in anti-freeze. [img]/ubbthreads/images/graemlins/frown.gif[/img]
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
post #5 of 9 (permalink) Old 11-05-2005, 07:09 PM
Don't know if you use ebay but check this out http://cgi.ebay.com/ebaymotors/Engin...11457216QQrdZ1
Could save a couple of dollars on the replacement parts.
Good luck
Ed
Ed
2001(Feb) extcab 350 SRW 7.3PSD Auto AIS Filter 57K mi, RotellaT 5w-40 synt
2000 VW Golf TDI 140K on
1987 MF 60H perkins
eszut is offline
post #6 of 9 (permalink) Old 11-05-2005, 10:17 PM Thread Starter
My Photos: (12)
Thanks for the info....
If it gets above 0 tomorow I will take a closer look at it....
Buddy_M wouldn't a wetvac suck the fluid out of the radiator ?????
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
xdodge is offline
post #7 of 9 (permalink) Old 11-05-2005, 10:37 PM
If you just stick the end of the hose in the opening, but not far enough into the fluid and block the opening with rags, it will not suck out any fluid. I have also done the shop-vac trick to replace bad drain plugs and gaskets on engines without losing a drop of oil.
post #8 of 9 (permalink) Old 11-06-2005, 12:04 AM
klhansen's Avatar
My Photos: (180)
xdodge,
I agree about the cord. Mine went bad right at the plug. Wires were broken, but looked good on the outside. NO HEAT (and no GPR) so took 20 min to get it fired up at around zero.
Go by West Marine and buy a Marinco Charger inlet, then truck on out to Eagle River, and I'll help you install it. The nose of your truck will fit in my garage, and I have the hole saw to cut the hole in the bumper. Shouldn't take more than an hour.
PM me if interested.
), AIS,
regulated return,
klhansen is offline
post #9 of 9 (permalink) Old 01-11-2014, 07:09 PM
I'm new on here as a member but I look at this site a lot for tips and pointers. Today I tried the vacuum trick to change my block heater on my 1999 ford f250 7.3 and when I pulled the heater out it sucked out all of my coolant before I could get the new heater in. I don't know if I done it right or what. I just put the vacuum hose on top of the radiator, the hose fit perfectly around the neck but it didn't work for me.
fastford392 is offline
